speechminer issue
hi ,
calls are not appearing in speechminer .but calls are updating ti the webdav and RPS without any issues .and old calls are playing fine
Check RPS log if call metadata is posted to interaction receiver.
Check ULogger on speechminer host if data is added to speechminer index. That index is the source of the list of calls in speechminer.
As Janis said, check the entire upload process on RPS level, where the recording must be uploaded onto IRWS and also onto IR (interaction receiver)
attached RPS ,RCSand HTCC logs , kindly advice
https://drive.google.com/open?id=1jHSgQRm5jWMZOka9D8FdBLUNlZLXIcQr
I see that RPS posted a call to Speech Miner.
2018-08-07 14:49:15,164 metadata_client DEBUG POST: http://GENESYSCCA/interactionreceiver: Response Status: 200
2018-08-07 14:49:15,164 process_metadata DEBUG Removing metadata record:
Question is if Speech Miner is able to insert new calls into it’s index. Please check the content of ULogger tool which can be found on SpeechMiner host.
Dear ,
thank you for your quick response , could you please advice what is the error says in ulogger
https://drive.google.com/open?id=13Y5NjDVbbN9Bdb6jTd89NH0RuSVNAduW
Your problem is “the index task is in passive state”. But I don’t know how to solve it. I just can say that this passive state is OK for one node in case of duplicated SM. At least one node should insert new calls in the index regulary. Initiator of that indexing is UPlatform service. That is it what I know, I’m sorry.
Check your SM configuration - at least on Index configuration tab.
With this whole info you better open an eSR with Genesys
Enviado de meu E6633 usando o Tapatalk
hi
iindex are ok.. i dont have genesys support right now . and i am in needy situation
The highlighted log message has nothing to do with your problem. It is related to the Screen recording and not to the Call recording at all. from my point of view, your SM configuration is wrong as you can see the SM is not able connect to the RCS at least.
please tell me how can i enable speechminer UI
What do you mean by enable SM UI? I thought your UI is working properly, but you are not able to see any recordings within the UI.
in ulogger it says SpeechMiner UI cannot access HTCC Server. Screen Recording UI is disabled and
Error: createFromStream
Unable to read beyond the end of the stream.
at System.IO.__Error.EndOfFile()
at System.IO.MemoryStream.InternalReadInt32()
at d.a(BinaryReader A_0)
at i.a(Stream A_0, Int32 A_1, Int32 A_2)
What you have in IndexingStatustbl table in speech miner database?
What does speech miner Platform log say about Index?
Here is the ULogger screenshot from fully working system where we just do not have screen recording. To make you sure that there is nothing to do with the error about Speech Miner UI.
https://failiem.lv/u/xxf8s7ze
Main problem is the SM is not able connect to the RCS which is necessary to playback the recordings - check your SM configuration on recording tab and also check whether RCS is available for SM
It is not a problem at all :slight_smile: We just do not have license for screen recording on this site.
I’m not asking for help this time. This is to help Nofaul to locate the reason of his problems.
My post was not answer to your post, it is reaction to Noufal’s problem ;D
