Workforce Engagement Activity Points - Incorrect Calculation
Apologies if this is a basic question. How do I correct the activity points calculation in Workforce agement? We’ve noticed that the points are not adding up correctly for some agents-it’s showing zero even though they’ve handled calls and completed tasks.
The system appears to be ignoring some types of interactions. For example, if an agent handles a chat, it shows activity, but the points do not reflect that. Is there a setting I’m missing, or is it a permission issue?
Okay, so activity points - yeah, that’s a mess sometimes. We’ve got 1200 agents and wrestle with this every release.
  • First - double-check your interaction type mappings. Go to Admin - > WEM - > Activity Points Configuration. Make sure chat actually has points assigned. It’s easy to miss. The default templates are… optimistic about what people want.
  • Second, the API doesn’t always reflect UI changes immediately. Try a full refresh of the WEM data. Hit this endpoint: GET /api/v2/wfm/activitypoints/refresh. It’ll queue up a job. Expect a delay.
  • Third, and this is the one that got us last time, are you using custom interaction types? If you’re piping in data from something outside CXone - a custom IVR event, for example - you have to manually map that to an activity point. The system won’t guess. The docs are bad on this.
  • Also - are you looking at real-time data? Activity points are usually batched and processed overnight. What you see in the agent desktop now might not match what happened today.
  • Finally - are these agents new? Sometimes it takes a day or two for everything to sync up correctly after a new user is created. It’s a caching issue, as far as we can tell.
Let me know if you’re using custom interaction types - that’s where things get hairy.
yeah that’s right about the interaction mappings - we had a similar issue when setting up the chatbot handoff and auto-answer suggestions. did you check if the chat interaction type is actually linked to an activity point value? also, is the agent’s role set correctly in WEM - sometimes a basic agent role won’t pick up points even if the interaction is mapped.
We’re on Zoom Contact Center, Genesys Cloud - and it’s good advice to check the interaction mappings, like the earlier reply said. I’ve seen this - sometimes the WEM ACTIVITY_POINT_CONFIGURATION doesn’t get updated when a new interaction type is added, so you need to manually add the mapping like this: IF interaction_type = 'chat' THEN activity_points = 10. Also, check the agent’s PROFILE to make sure the WEM integration is enabled.
Cause: It’s like a plumbing system - if a pipe isn’t connected, nothing flows. The interaction type isn’t properly linked to the activity point configuration - even if it looks connected in the UI.
Solution: We spent three coffees debugging this - you need to make sure the interactionType field in your WEM activity point configuration matches exactly the interaction type returned in the event. Here’s a sample payload for the activity point configuration POST endpoint:
 "name": "Chat Points",
 "interactionType": "chat",
 "points": 10,
 "enabled": true
Double-check that interactionType - capitalization matters.
