Where does the Keyname get it's values from
Hi
anyone tell me where does colum ‘KEYNAME’ in ‘EVDATA’ get it’s values from?
Gondi
Gondi,
it gets is from EventData option inside CCon CME settings. You would setup it up as [type],[keyname],[type],[keyname] so that CCon would know what to save. So, if you have two attach data a and b, then you would say char,a,char,b
I am curious, but why are you using EVDATA? I would suggest using EVREFEX instead, since it would make your life much, much easier!
