what is the max size for attach data?
Hello all,
Could you please confirm what is the maximum size for attach data?
ex: 64K, 128k
Thanks & Regards,
Lakshmanakumar Krishnasamy
I think it is 16k bytes. You can find out it within available documentation.
It is configurable in TServer/SIP Server:
user-data-limit
Default Value: 16000
Valid Values: 0–65535
Changes Take Effect: Immediately
Specifies the maximum size (in bytes) of user data in a packed format.
If you set it too high you then have to make sure you have the necessary bandwidth.
Jummm what you can configure is a value between 0 and 64kb to limit bandwidth, but the max value is 64, can’t go beyond that.
Thanks Kubig, PeteHoyle and cavagnaro
