WFM schedule PATCH returning 400 on timezone conversion for Mexico City
The Laravel queue worker is hanging on this WFM schedule sync. We’ve got a custom internal tool built on Laravel 10 using Guzzle 7.8 to push agent availability blocks into the platform. The goal is to auto-update the WFM schedule based on data from an external legacy system. The agents are based in Mexico City, so the local times need to map correctly to the platform shifts.
First, the auth token is cached in Redis, so that’s not the bottleneck. The token refreshes every 35 minutes without issue. The request hits /api/v2/wfm/schedule/agent/{agentId}. The payload structure matches the schema exactly. The code is passing the start and end timestamps in ISO 8601 format.
Here’s the logic flow. The legacy system spits out local times. The code converts everything to America/Mexico_City before sending. The Guzzle request looks like this:
$response = $client->patch("api/v2/wfm/schedule/agent/{$agentId}", [
 'json' => [
 'schedule' => [
 'blocks' => [
 'start' => '2023-10-27T09:00:00-06:00',
 'end' => '2023-10-27T17:00:00-06:00',
 'availability' => 'AVAILABLE'
 'headers' => ['Authorization' => "Bearer {$token}"]
The response comes back with a 400 Bad Request. The error payload points to the start field. It claims the timestamp is invalid. This is weird because the -06:00 offset is valid for Mexico City. The code is doing jack all to modify the string before the request fires. I’ve tried stripping the offset and letting the server default to UTC, but that shifts the schedule by six hours, which breaks the shift alignment.
Switching the offset to -05:00 works, but that’s the wrong timezone for the agents. The docs mention that WFM endpoints expect UTC, but the error message explicitly says “Invalid timezone offset”. The validation error is super vague. The Laravel logs show the exact string being sent. The offset is definitely there. The token has the wfm:write scope. The agent ID resolves correctly via the GET /api/v2/users endpoint first. The 400 hits on the PATCH.
The timezone offset seems to be the trigger. Removing it causes a 422 due to “Missing offset”. Adding -06:00 causes a 400 “Invalid offset”. Adding Z for UTC works, but the schedule shifts. The WFM schedule needs to show 09:00 Mexico time. Forcing Z makes it show 09:00 UTC, which is 03:00 or 04:00 local time depending on DST. The agents show up as scheduled at 3 AM.
The code tries to force the offset via Carbon:
$start = Carbon::parse($rawTime)->timezone('America/Mexico_City')->toIso8601String();
This outputs 2023-10-27T09:00:00.000000Z if I use toIso8601String() without arguments, or 2023-10-27T09:00:00-06:00 if I force it. The latter breaks the API. The former works but breaks the time. The Guzzle request throws the exception immediately. No retry logic kicks in because the 400 is treated as a client error. The loop stops. The queue job fails after three attempts. The error handler dumps the payload.
 "request": "PATCH /api/v2/wfm/schedule/agent/5a1b2c3d-4e5f-6g7h-8i9j-0k1l2m3n4o5p",
 "payload": {
 "schedule": {
 "blocks": [
 "start": "2023-10-27T09:00:00-06:00",
 "end": "2023-10-27T17:00:00-06:00",
 "availability": "AVAILABLE"
 "status": 400,
 "error": "Invalid input: start"
The platform seems to hate the -06:00 string. Is there a way to pass the timezone explicitly in the header, or does the WFM API strictly require UTC with a separate timezone field in the JSON body? The schema docs for WFM are thin on this. The generic schedule endpoint doesn’t mention timezone handling. The payload structure remains identical to the working UTC version, just the offset changes. The error persists. The queue is filling up with failed jobs. The agents are missing their schedules for tomorrow. The code is stuck on this offset validation.
The platform API doesn’t play nice with ambiguous offsets. You’re probably sending a raw offset when the WFM engine expects a named timezone ID. It chokes on the conversion logic and throws a 400.
Fix the payload structure before Guzzle hits the endpoint.
  1. Set timezone_id to exactly America/Mexico_City.
  2. Format start_time and end_time as strict ISO 8601 strings.
  3. Drop any legacy utc_offset fields from the request body.
 "timezone_id": "America/Mexico_City",
 "schedule_entries": [
 "start_time": "2024-05-15T08:00:00-05:00",
 "end_time": "2024-05-15T17:00:00-05:00",
 "availability_code_id": "available"
Update the agent’s schedule using the appropriate WFM endpoint with that exact shape. Make sure your bearer token actually has the wfm:users:write scope attached. The gateway validates the timezone string against IANA standards before it even touches the shift boundaries. Don’t overcomplicate the offset math.
Problem
The WFM endpoint chokes on raw offsets. Data Actions handle this by forcing the server timezone.
Code
"timezone_id": "America/Chicago",
"start_time": "2024-08-01T09:00:00-05:00"
Error
Leaving the offset blank triggers a silent validation fail. The PATCH still bombs with a 400.
Question
Does the Laravel worker need a custom middleware to strip the trailing Z before Guzzle sends it?
Ran that payload through my ETL sync last night. Needed to verify the timezone handling before the Snowflake load. Here is what I tested.
First attempt: sent raw UTC offsets with timezone_id omitted. Platform returned a 400 immediately. Second attempt: switched to America/Mexico_City but kept the offset in the datetime string. Still failed. Third attempt: stripped the offset from the datetime and let the timezone_id handle the conversion. Patch went through clean.
curl -X PATCH "https://api.mypurecloud.com/api/v2/wfm/schedule/users/availability" \
 -H "Authorization: Bearer $GC_TOKEN" \
 -H "Content-Type: application/json" \
 -d '{
 "schedule": [
 "start_time": "2024-08-01T09:00:00",
 "end_time": "2024-08-01T17:00:00",
 "status": "available"
The WFM engine definitely expects the server to resolve the offset when the named ID is present. You don’t need to calculate DST shifts manually in the payload anymore. Watch out for bulk limit throttling if you’re patching hundreds of agents in a single run. The endpoint caps at 200 records per request and it’ll silently drop excess items instead of throwing a 429.
Does the PureCloudPlatformClientV2 SDK handle this offset stripping automatically, or do we have to sanitize the datetime strings in the middleware layer? Running a quick test on the bulk details endpoint shows the continuation token still breaks on page three when the conversion runs. Gonna dig into the raw job logs tomorrow.
The WFM API documentation explicitly states that timezone shifts require strict ISO formatting.
Problem
Mexico City offsets break the WEM pipeline.
Code
Error
Verify your OAuth Scopes include wfm:schedule:write first.
Question
You’ll hit validation blocks if the KEY CONFIGURATIONS miss the region flag. The parser chokes on mixed offsets. Just drop the trailing Z.
