WEM Adherence Timeout on Shift Trade Reconciliation
The WEM Adherence dashboard throws a Data Aggregation Timeout (ERR_WEM_4082) when the reporting engine tries to reconcile approved shift trades against the published baseline. We’re running Genesys Cloud BYOC edge v23.8 in Virginia with WEM client build 2024.02. Forecasted shrinkage looks fine in the planning module, but the actuals report flags a twelve percent gap during peak afternoon intervals. Queue adherence drops the moment agents swap blocks. The system isn’t recognizing trade approvals as valid working time, which skews service level calculations for the desk. Console logs show the service timing out after fifteen minutes, even though agent status history pulls correctly in the real-time monitor.
Are the approval timestamps aligning with the New York timezone offset, or does the engine default to UTC for historical compliance data? The management unit definitely has the trade policy set to auto-approve, but analytics ignores those flags during the nightly rollup. The numbers are doing jack all during the swap period. Checking the cache refresh intervals now. Or maybe it’s just a BYOC pipeline bottleneck waiting for the next patch
{ "filter": { "type": "shift_trade", "status": "approved" }, "interval": "PT15M" }
The dashboard isn’t actually dropping the trades, it’s just hitting the legacy polling limit like we see on the chat widget routing queues. Post that payload directly to the shift trade jobs endpoint to bypass the aggregation lock, and the adherence calc won’t refresh until you route around it.
The timeout fires because your token lacks wfm:schedules:edit. The suggestion above works once you fix it. The docs state “Shift trade reconciliation requires wfm:schedules:edit and wfm:adherence:view.” Why doesn’t it work when hitting /api/v2/wfm/scheduling/shifts/trades? You’ll need a fresh grant.
curl -X POST https://api.mypurecloud.com/api/v2/oauth/token \
 -H "Authorization: Basic {base64}" \
 -d "grant_type=client_credentials&scope=wfm:schedules:edit wfm:adherence:view"
Cache breaks on expiry anyway.
Error: 408 Request Timeout. The adherence calc finally stopped hanging after I patched the scope on the service account.
The suggestion above nailed it. I was staring at the dashboard thinking it was a BYOC edge latency issue because we’re on the Virginia node. The default app I spun up in Terraform only had view permissions, so the reconciliation request was getting rejected silently until the timeout hit.
I had to explicitly grant wfm:schedules:edit. The docs mention it, but the error message doesn’t tell you which scope is missing. Here’s the config block that fixed the drift.
resource "genesyscloud_auth_application" "wfm_recon" {
 name = "wfm-reconciliation-runner"
 scopes = [
 "wfm:adherence:view",
 "wfm:schedules:edit",
 "wfm:users:view"
Running the plan again shows zero drift. The trades reconcile instantly now. Don’t forget to rotate the token if you update the scopes on an existing app. Terraform doesn’t always catch that dependency. It’s 3am here so I’m testing this before the US shift hits.
Re-running the apply.
