Daer All,
Have someone can fix this log file?
I try to install cobrowsing. First of all, I already install Kana and test it, so my testing is pass (only Kana). After that I’ve installed cobrowserver in the same server but when i started it started and stopped suddently. The log file show as below
11:56:20.828 Std 20001 (Cobrowse) Genesys Cobrowse server starting. Metrics version is [7.5.005.00]
11:56:20.828 Trc 20100 (Cobrowse) Server alias: kana
11:56:20.843 Trc 20100 (Cobrowse) Database type = mssql
11:56:20.843 Trc 20100 (Cobrowse) Database driver = com.microsoft.jdbc.sqlserver.SQLServerDriver
11:56:20.843 Trc 20100 (Cobrowse) Database URL = jdbc:microsoft:sqlserver://alaska:1433;SendStringParametersAsUnicode=true;SelectMethod=cursor;DatabaseName=cobrodb
11:56:20.843 Trc 20100 (Cobrowse) Database user = sa
11:56:20.843 Std 20002 (Cobrowse) Cobrowse server is ready to work.
11:56:22.906 Trc 20100 (Cobrowse) Connection to DB ; Begin
11:56:22.906 Trc 20100 (Cobrowse) DBase Type: mssql
11:56:22.921 Trc 20100 (Cobrowse) Driver com.microsoft.jdbc.sqlserver.SQLServerDriver has been loaded.
11:56:22.937 Trc 20100 (Cobrowse) Connection established.
11:56:22.937 Trc 20100 (Cobrowse) Statement created
11:56:22.953 Dbg 20400 (Cobrowse) Attempt to create table CB_USER : [Microsoft][SQLServer 2000 Driver for JDBC][SQLServer]There is already an object named ‘CB_USER’ in the database.
11:56:22.968 Dbg 20400 (Cobrowse) Attempt to create table CB_ID : [Microsoft][SQLServer 2000 Driver for JDBC][SQLServer]There is already an object named ‘CB_ID’ in the database.
11:56:22.968 Dbg 20400 (Cobrowse) Attempt to create table CB_USER_ACTIVITY : [Microsoft][SQLServer 2000 Driver for JDBC][SQLServer]There is already an object named ‘CB_USER_ACTIVITY’ in the database.
11:56:23.062 Dbg 20400 (Cobrowse) Attempt to create table CB_SESSION_EXT : [Microsoft][SQLServer 2000 Driver for JDBC][SQLServer]There is already an object named ‘CB_SESSION_EXT’ in the database.
11:56:23.062 Dbg 20400 (Cobrowse) Attempt to create table CB_USER_IN_SESS : [Microsoft][SQLServer 2000 Driver for JDBC][SQLServer]There is already an object named ‘CB_USER_IN_SESS’ in the database.
11:56:23.078 Dbg 20400 (Cobrowse) Attempt to create table CB_LINK_CONAVIG : [Microsoft][SQLServer 2000 Driver for JDBC][SQLServer]There is already an object named ‘CB_LINK_CONAVIG’ in the database.
11:56:23.078 Dbg 20400 (Cobrowse) Attempt to create table CB_EVENT_TYPE : [Microsoft][SQLServer 2000 Driver for JDBC][SQLServer]There is already an object named ‘CB_EVENT_TYPE’ in the database.
11:56:23.078 Dbg 20400 (Cobrowse) Attempt to create table CB_MASTER_MEDIA_TYPE : [Microsoft][SQLServer 2000 Driver for JDBC][SQLServer]There is already an object named ‘CB_MASTER_MEDIA_TYPE’ in the database.
11:56:23.687 Trc 55206 Shutting down server…
11:56:23.687 Trc 55207 Shutting down connection manager…
11:56:23.687 Trc 55209 Closing configuration server…
11:56:23.687 Trc 55210 Closing logging service…
Thank you in advance,
Lekie
