Your used vbscript.dll is in windows/system32 and is ok. There is also some known troubles with anti-virus softwares
Policy:
As a general policy/approach, anti-virus software should be disabled on server boxes. Any anti-virus software decreases server performance and can block server applications from normal operation. Most mission critical servers’ integrity should be protected from internal and external threats by using limited network access, security policies, firewalls, and other organizational means.
Anti-virus should be used on client/agent facing boxes. See list of known issues for client components. Check Release Notes for each product for known issues. Contact Support for newly discovered issues.
Technical Support will accept all Genesys related problems faced during the use of anti-virus software for analysis and will provide recommendations and explanations for these issues. Client may be required to provide either license or trial version of the anti virus software for complete analysis. In most cases the subsequent solution (recommended configuration changes, enabling/disabling particular scanners) should be addressed by anti-virus vendor.
Preferred Vendors:
At this point there is no particular vendor or anti-virus suite that Genesys would recommend/require/approve for use or guarantee to function reliably. We do have a preferred anti-virus solution: Trend Micro Office Scan; which is used in-house. In most cases, anti-virus should not negatively affect agents’ work.
PS Original source ER #68521
Known problems with adverse effects are listed below.
There are no other known issues at this time.
client: CCPulse
anti-virus: McAffee, Norton : the problem is with McAffee product memory leak while checking Visual Basic Scripts execution.
Note of incompatibility with Genesys is published on vendor site:
http://knowledge.mcafee.com/SupportSite/search.do?cmd=displayKC&docType=kc&externalId=KB40067&sliceId=SAL_Public&dialogID=1168942&stateId=1%200%201172245
Workaround is to upgrade McAffee suit to th latest versions or disable script scan as described on vendor side.
client: Internet Explore browser working with Genesys Desktop server
antivirus: any online Web traffic scan/monitor.
Performance maybe affected (responsiveness slowdown in up to 20 times) depends on the CPU speed and Memory volume of the client box.
If customization is used and custom files are infected - they can be blocked by antivirus scanner - this should be addressed by customization developer.
client: MCR/ICS Email Server Java downloading messages from corporate POP3/IMAP Server
antivirus: any online POP3/IMAP traffic monitor, email file format monitor.
Software can block download/use of emails with viruses. ICS ESJ has enchancements that will allow normal work - but see Release Ntoes on special handling. For MCR it is recommended to use Server Side antivirus.
For GVP components same considerations as fro Genesys Desktop applies. Online web traffic scanner/monitor may impact performance.
Date Last Updated: 10/31/2006 19:45:19
