Hi
Does anyone have the VB code required to make the cells flash in CC PUlse when thresholds are reached? Would be very grateful if you could let me have a copy ;D
Hi
why does it need to flash ??? is bright red not visible enough for when thresholds are breached? ???
I thought that bright red would be enough, although this is one of the many strange requests I get? I know it is possible will have to take time away and design something I think. Cheers
I made the rookie mistake of mentioning the flashing colours and have been asked to look into it too :-[
If I come up with something i’ll post it, if you come up with something can you?
;D will do ;D
This is not a clean blink and you would need to modify it to suit the selected metric to make sure the 3 seconds works well with your update frequency etc. but, its a rough idea if you are desperate enough for it.
if Threshold.StatValue = StatAction.SDNALoggedOut then
if Second(Now()) Mod 3 > 0 then
Threshold.Result = true
else
Threshold.Result = false
end if
end if
cool,
ill have a play with that one today
Cool, thanks for that will have a go later today ;D ;D
