Terraform Plan in PR fails with state lock despite remote backend
We’re trying to automate Genesys Cloud resource provisioning using Terraform. The goal is to run terraform plan on pull requests and terraform apply on merge, but the plan step consistently fails with a state lock error.
The backend is configured to use the GC API for state storage. Is there a specific header or concurrency setting required in the CI job to prevent this lock when multiple PRs are open simultaneously?
Using the Genesys Cloud API as a Terraform backend is a bad idea. The platform doesn’t support the locking primitives Terraform needs for safe concurrent access, which is why your plans are crashing. I tried this exact setup in my Azure Functions pipeline last year and hit the same wall. The state file gets corrupted or locked indefinitely because GC treats the PUT request as a standard data update, not a distributed lock acquisition. You’ll end up with race conditions every time two PRs trigger at the same time. The docs for external backends clearly state that S3, Azure Blob, or GCS are the supported options for this reason. Don’t fight the platform’s limitations here.
Switch to a standard remote backend like AWS S3 or Azure Blob Storage. It’s trivial to set up and handles the locking automatically. Here is a minimal HCL config for Azure Blob, which works perfectly with my C# integrations:
terraform {
 backend "azurerm" {
 resource_group_name = "tf-state-rg"
 storage_account_name = "tfstateacct"
 container_name = "tfstate"
 key = "genesys-prod.tfstate"
Make sure the service principal or managed identity has Storage Blob Data Contributor permissions. This separates your state management from your Genesys resources. Once the backend is moved, your CI/CD pipeline will handle parallel plans without errors. The GC provider will still talk to the API for resource creation, but the state file stays safe. I’ve been running this pattern for three years now. It just works.
