Running into a weird block with our new CI/CD setup for Genesys Cloud resources. We’re trying to use the genesyscloud Terraform provider to manage WEM rules and routing configurations. The plan is simple: run terraform plan on every Pull Request to see what will change, and then run terraform apply only when the PR gets merged into the main branch.
The problem is that the plan step in the PR workflow keeps failing. It throws a state lock error saying the state file is locked by another operation. But I’m pretty sure no other apply is running. I suspect the issue is how we are handling the backend configuration or maybe the remote state locking isn’t playing nice with the parallel nature of GitHub Actions.
Here is the relevant part of our terraform-pr.yml workflow:
name: Terraform Plan on PR
on:
pull_request:
branches: [ main ]
paths:
- 'infra/**'
jobs:
plan:
runs-on: ubuntu-latest
steps:
- uses: actions/checkout@v3
- name: Setup Terraform
uses: hashicorp/setup-terraform@v2
with:
terraform_version: 1.5.0
- name: Init
run: terraform init
env:
GCS_KEY: ${{ secrets.GENESYS_OAUTH_CLIENT_ID }}
GCS_SECRET: ${{ secrets.GENESYS_OAUTH_CLIENT_SECRET }}
GCS_REGION: ${{ secrets.GENESYS_REGION }}
- name: Plan
run: terraform plan -out=tfplan
env:
And the error output looks like this:
Error: Error acquiring the state lock
Lock Info:
Path: gen-terraform-state/terraform.tfstate
Operation: OperationTypeApply
Who: ci-runner@example.com
Version: 1.5.0
Created: 2023-10-27 14:00:00 +0000 UTC
Info:
It says OperationTypeApply but I didn’t trigger an apply. Did someone else merge something? Or is the plan step somehow acquiring a lock that conflicts with itself? I tried adding -lock=false to the plan command just to see if it would work, and it did run, but that feels dangerous since we want to prevent accidental overwrites in production.
Is there a specific way to configure the backend or the workflow to handle concurrent plans without locking errors? Or is this a known issue with the Genesys provider and remote state?
