Running into a weird issue with our Terraform pipeline for Genesys Cloud. We are managing routing queues via the genesyscloud_routing_queue resource. The plan command shows drift on the name attribute, even though the API shows the name is correct. Worse, terraform refresh fails with a state lock error.
Here is the resource definition:
resource "genesyscloud_routing_queue" "support_queue" {
name = "US Pacific Support"
description = "Main support queue for Pacific timezone"
enabled = true
The error output looks like this:
Error: Error acquiring the state lock
Lock Info:
Path: state.tfstate.lock.info
Operation: OperationTypeRefresh
Who: user@corp.com
Version: 1.0.0
Created: 2023-10-27T10:00:00.000Z
Info:
I have tried:
- Running
terraform force-unlockwith the lock ID. It says the lock doesn’t exist or is stale. - Checking the remote backend (S3) for stale lock files. Nothing there.
- Manually verifying the queue name via POST
/api/v2/routing/queues/{id}. The name matches exactly. - Clearing the local state cache and pulling fresh.
The drift persists. The plan shows:
~ resource "genesyscloud_routing_queue" "support_queue" {
~ name = "US Pacific Support" -> "US Pacific Support"
This is confusing. The value hasn’t changed, but Terraform thinks it has. The state lock error prevents me from fixing the state file directly. Is this a known issue with the Genesys Cloud provider? Or is there a race condition with the API during refresh?
We are using Terraform 1.5.2 and the Genesys Cloud provider v1.0.100. The environment is us-east-1. Any ideas on how to break this loop?
