Terraform import for Genesys Cloud routing queues throwing 404 on read
Hey folks. I’m trying to import an existing Genesys Cloud routing queue into my Terraform state so I can start managing it as code. I’ve got the queue ID from the UI, but when I run terraform import, the provider immediately fails with a 404.
Here’s the command I’m running:
terraform import gen_cloud_routing_queue.support_queue 12345678-1234-1234-1234-123456789012
The error output says:
Error: Resource not found
with gen_cloud_routing_queue.support_queue,
on main.tf line 1:
1: resource "gen_cloud_routing_queue" "support_queue" {
I can hit GET /api/v2/routing/queues/12345678-1234-1234-1234-123456789012 directly in Postman and get a 200 OK with the full JSON payload. The auth token is the same service account used for the Terraform provider. I’ve double-checked the environment variable in my terraform.tfvars and it matches the region.
Is there a specific attribute I need to define in the resource block before importing? I usually just define the name and try to let the provider fetch the rest. The docs are a bit sparse on pre-requisites for the import command. I’ve tried adding description and outbound_email fields, but no luck. It feels like the provider is trying to read a nested attribute that’s null on the API response, but the error isn’t specific enough to tell me which one.
Check the provider docs, terraform import expects the id attribute specifically, not the internal system id. If that’s already what you’re using, the resource might be in a different org or deleted, so verify the ID via the /api/v2/routing/queues/{id} endpoint first.
is spot on. Run a quick curl to /api/v2/routing/queues/{id} first to confirm the ID exists and you have access. If that returns 404, Terraform will too.
