Terraform for_each with YAML vars for Queues
Parsing YAML for for_each is messy. The yamldecode function works fine for simple maps, but queues need nested attributes like outbound_calling and wrap_up_timeout_millis. When I pass the decoded map to the resource block, Terraform complains about complex types not being supported in the variable definition.
Here’s the setup:
locals {
 queues_map = yamldecode(file("queues.yaml"))
resource "genesyscloud_routing_queue" "this" {
 for_each = local.queues_map
 name = each.value.name
 # How do I handle the nested outbound_calling block here?
The YAML structure looks like this:
queue_1:
 outbound_calling:
 enabled: true
It fails on apply because the provider expects a specific block structure, not a flat map value. I’m stuck trying to map the YAML keys to the required HCL blocks without writing a custom provider or manual resource blocks for every queue. Anyone got a clean pattern for this?
Look, I usually stick to webhook delivery logs and retry policies, but I’ve seen this YAML mess enough times to know it’s a pain. The issue isn’t really yamldecode. It’s that Terraform’s type system chokes when you try to map complex nested objects directly into a for_each without explicit typing. You’re getting those errors because Terraform doesn’t know if outbound_calling is a string, a map, or null until runtime.
You need to define a custom type for your queue config in the variables file. Don’t just pass the raw decoded object. Wrap it in a structure Terraform understands. Here’s how I’ve handled it in my own setups to keep things clean.
variable "queue_configs" {
 type = map(object({
 name = string
 description = string
 wrap_up_timeout_millis = number
 outbound_calling = object({
 enabled = bool
 default = {}
locals {
 # Force the YAML data into the expected type
 typed_queues = { for k, v in var.queue_configs : k => v }
resource "genesyscloud_routing_queue" "queues" {
 for_each = local.typed_queues
 description = each.value.description
 wrap_up_timeout_millis = each.value.wrap_up_timeout_millis
 outbound_calling {
 enabled = each.value.outbound_calling.enabled
In your terraform.tfvars, you’ll still use yamldecode, but you pass it into the variable definition explicitly. This forces Terraform to validate the structure before it hits the resource block. It’s a bit more verbose upfront, but it saves you from those runtime type mismatches. The outbound_calling block needs to be an object, not just a boolean. If you leave it as a flat boolean in the YAML, the type check fails. Make sure your YAML matches the object structure exactly. Also, check that your API user has routing:queue:write scope. Missing scopes often look like type errors in Terraform logs.
