Trying to map a YAML list of queue configs to for_each in the Genesys Cloud provider. The YAML parses fine into a map, but the resource block complains about attribute types. I’ve got queues.yaml with names and descriptions.
locals {
queues = file("queues.yaml")
resource "genesyscloud_routing_queue" "this" {
for_each = local.queues
name = each.value.name
Hitting a validation error on name. How do you structure the YAML so the provider accepts it without manual map conversion?
Docs state: “The yamldecode function parses YAML content into a map or list structure.” You’re likely missing the actual parsing step. file() just returns a string. Terraform doesn’t magically know YAML.
Here is the working pattern for mapping YAML to for_each.
locals {
# Parse the YAML file into a map structure
raw_queues = yamldecode(file("queues.yaml"))
# Convert to a map keyed by name or ID for for_each
# Assuming your YAML is a list of objects
queues_map = { for q in local.raw_queues : q.name => q }
for_each = local.queues_map
name = each.key
description = each.value.description
enabled = true
Your YAML should look like this:
- name: "Support Tier 1"
description: "First line support"
- name: "Support Tier 2"
description: "Escalation queue"
The error on name happens because local.queues was a string, not a map. for_each expects a map or set. If you use yamldecode on a map directly in YAML (key: value pairs), you can skip the for expression.
Support Tier 1:
Then local.queues = yamldecode(file("queues.yaml")) works directly with for_each.
Check the genesyscloud_routing_queue resource docs. It requires name to be a string. If your YAML has nested objects, you need to flatten them or use the correct key.
Also, don’t forget division_id if you’re not using the default. Missing that causes silent failures or wrong placement.
name = each.key
division_id = var.default_division_id
Run terraform validate after fixing the parse step. It usually catches the type mismatch.
