Terraform apply on merge failing with state lock conflict
How do you handle state locking when the pipeline runs apply on merge? We have the plan step working fine on the PR, but the merge job fails with a state lock error because the plan process hasn’t fully released the lock yet. The GitHub Actions workflow uses the standard hashicorp/setup-terraform action. Is there a specific timeout setting we need to adjust in the provider block or is this a race condition in the CI runner?
State locking in Terraform is usually a backend issue, not a provider timeout. You’ll want to ensure your GitHub Actions workflow uses a mutex or a dedicated lock file step before the apply runs. It’s a common race condition in CI pipelines.
Try adding a hashicorp/consul-api-action or using the tflock action to manage the lock explicitly. This prevents the plan and apply jobs from stepping on each other’s toes during the merge window.
