Synchronization of ICON 7.5 for CFG data not working.
Synchronization of ICON 7.5 for CFG data not working, but it works for update of cfg data.
for 7.6, there is start-cfg-sync option for cfg data synchronization purpose, for 7.5 ,how to invoke the initial synchronization for CFG Data?
Thanks.
First set start-cfg-sync to -1, apply, (this step is not in the documnentation)
then 0 apply,
finally 1 apply
That should do it.
If it does not do it then restart Icon Cfg and that will also reload the config.
regards
Allan
