Strange behaviour of after-call-divert-destination
Have a question regarding strange behavior of ExtensionUpdate[‘after-call-divert-destination’,DN] function in genesys. It supposed to divert a call after interaction with agent ends to a different routing point (eg for surcvey, etc), so it does. But strangely after second strategy (survey) ends it does not hang the call, stays with silence. Can you help with that issue? Is it our local problem, or genesys bug?
The problem is not in survey itself, because I created simple strategy that sets aftercall divert and dials test agent, and after call release by agent it diverts to other strategy that simply plays message and goes to exit block. But call stays online with silence instead of being released.
T-server version is 8.1.102.35
You have to release/disconnect it within your routing strategy, the exit block does not do it.
Added ReleaseCall function before exit block - did not help.
Try to use Disconnect function
Cant find Disconnect function. Can you help me with that?
In log there is a error message
AttributeErrorMessage ‘Object not known’
AttributeRouteType 7 (RouteTypeReject)
And if I set up a strategy to ReleaseCall without setting an aftercalldivert option - Route is OK. Call terminates.
I think aftercalldivert breaks Reject route somehow. Why?
I am always using the TRoute function with RouteType equal to “RouteTypeCallDisconnect” and it works as expected.
You mean TRoute[‘’,‘’,RouteTypeReject,‘’]?
Already did that, got error message in log, posted before.
Can anyone assemble lab with 2 strategies on 2 RPs, where one sets ExtensionUpdate[‘after-call-divert-destination’, XXXX], where XXXX is second RP, and second strat just plays some message and either uses TRoute or ReleaseCall to release call.
I can’t understand why system unable to find route to reject?
No, I meant TRoute[‘’,‘’,RouteTypeCallDisconnect,‘’]
Ok, tried TRoute[‘’,‘’,RouteTypeCallDisconnect,‘’]
Got:
AttributeErrorCode 1143
AttributeReferenceID 4823057
AttributeReason [14] 00 01 01 00..
‘RTR’ 886
AttributeRouteType 14 (RouteTypeCallDisconnect)
AttributeOtherDN ‘’
Weird, have to check entire logs, because it working in general cases.
Well - found a ‘solution’
Created RP with no strategy and TRouted to it. Succesfully drops the call. But that is not right at all.
Can anybody please just repeat my case to check is that a bug or a feature? Is it necessary to open genesys care case for that, or its just our enviromnment broken somehow?
What version of SIP server are you using? I will check the function within my LAB
posted before
8.1.102.35
Thanks!
Just have tested it and it works as expected, my call flow is:
Initial RP → Agent → Agent disconnect the call → SIP forward the call at the “divert” RP → Strategy is executed and the call is disconnected/released
Well that’s quite embarrasing. Thanks for testing!
Don’t know where to look for the reason why it is broken, any suggestions?
Try to post the SIP logs covering the RequestRouteCall and upcoming events
Whited out with ***** some server names
message RequestRouteCall
AttributeThisDN ‘4901’
AttributeConnID 037a028a72261ff0
AttributeOtherDN ‘’
AttributeExtensions [53] 00 02 00 00..
‘CUSTOMER_ID’ ‘Environment’
‘SWITCH’ 'SIPSwitch_’
‘RTR’ 886
AttributeReferenceID 4829626
15:44:24.597 Int 04543 Interaction message “RequestRouteCall” received from 820 ("URServer_P_
@15:44:24.5970 [ISCC] destination_location substituted by local
15:44:24.597 – created: CRequest@98f69f0 RequestRouteCall-URServer_P_[820]/4829626
15:44:24.597: $+TLIB:CTI:Unknown:0:145
15:44:24.597 +++ CIFace::Request +++
– new invoke
15:44:24.597 Trc 36210 Client 7(URServer_P_
): no destination DN in request
– thisCall by party
Parsed: RequestRouteCall
Numbers: +<4901> -
Calls: 5485030:1 none
Parties: 4901.538e040-5485030:1
none
Status: parsed:1 queued:0 sent:0 acked:0 preevent:0 event:0 context:0 transferred:0
– validate
– state check: ok
CIFace: Sent CRequest@98f69f0 RequestRouteCall-URServer_P_[820]/4829626
– created NAData c333620
FinishRequest CRequest@98f69f0 RequestRouteCall-URServer_P_
[820]/4829626
IFace stats: q=0 s=0
– complete
– NAData ClRq removed
TNAEmulator::NotifyBackup()
@15:44:24.5970 [BSYNC] Trace: Send to backup (SIPServer_B_*****) [852]:
message EventUserEvent
attr_#1005 0
attr_#1004 597
attr_#1003 1471956264
attr_#1002 2282910
attr_#1001 5
attr_#1000 131072
AttributeAgentWorkMode 0 (Unknown)
AttributeAgentStateReasonUnused 1
@15:44:24.5970 [BSYNC] Trace: Sent
15:44:24.597: RID:CUUID>4829626:4I61R0DBQD48L514OGJQEPMOPK001G58:
15:44:24.597: IncrementRouteRequestCounter, option 100
15:44:24.597: $*:CTI:SIP:ROUTE_CALL:800282
15:44:24.597 — CIFace::Request —
15:44:24.597: $-TLIB:CTI:Unknown:0:769
15:44:24.597: $+SIP:CTI:SERVICE_COMPLETION_FAILURE:4095470:248
15:44:24.597 Trc 36210 Client 7(URServer_P_): no destination DN in request
15:44:24.597 – thisCall by party
@15:44:24.5970 [0] 8.1.102.35 send_to_client: message EventError
(Object not known)
AttributeEventSequenceNumber 0000000000f3c3fd
AttributeTimeinuSecs 597000
AttributeTimeinSecs 1471956264 (15:44:24)
‘RTR’ 886
AttributeOtherDN ‘’
AttributeClientID 7
15:44:24.597 Int 04545 Interaction message “EventError” sent to 820 ("URServer_P_")
15:44:24.597 Trc 04542 EventError sent to [820] (00000007 URServer_P_
*****:55502)
15:44:24.597: internal error, RequestRouteCall failed without cleanup
15:44:24.597: $-SIP:CTI:SERVICE_COMPLETION_FAILURE:4095470:284
I think your sip server is not aware of that RP. Try a reset
