Strange behaviour of after-call-divert-destination
On the TRoute you put the RP, right?
It seems that you have SIP server configured in other way than my LAB, you can post your app options to check them.
In this case i just do TRoute[‘’,‘’,RouteTypeCallDisconnect,‘’]
What RP should I put there? Current strategy RP?
I guess something and not blank. Kubig may know better. You are telling URS to route to nothing. Try that other RP
In this case, the OtherDN is empty and it is right, because you just want to hangup the call. As I said, in my LAB it works as expected, so I guess some miconfiguration on SIP server application object level
:-X Ok, didn’t say anything then.
Try a reset of the SIPServer just in case.
Ok. I created RP 4902 with simple message. Trouted to it. No message played, but call cleared.
Strange things are happening in logs. It uses our international trunk to route to that destination, and I think gets nothing, thus clearing the call…
message RequestRouteCall
AttributeThisDN ‘4901’
AttributeConnID 037a028a722620fa
AttributeOtherDN ‘4902’
AttributeExtensions [53] 00 02 00 00..
‘CUSTOMER_ID’ ‘Environment’
‘SWITCH’ 'SIPSwitch_’
AttributeRouteType 14 (RouteTypeCallDisconnect)
AttributeReason [14] 00 01 01 00..
‘RTR’ 886
AttributeReferenceID 4833323
16:27:35.994 Int 04543 Interaction message “RequestRouteCall” received from 820 ("URServer_P_
@16:27:35.9940 [ISCC] destination_location substituted by local
16:27:35.994 – created: CRequest@3dd3570 RequestRouteCall-URServer_P_[820]/4833323
16:27:35.994: $+TLIB:CTI:Unknown:0:75
16:27:35.994 +++ CIFace::Request +++
– new invoke
– thisCall by party
Parsed: RequestRouteCall
[820]/4833323
Numbers: +<4901> +<4902>
Calls: 4cdc710:1 none
Parties: 4901.b4ae580-4cdc710:1
none
Status: parsed:1 queued:0 sent:0 acked:0 preevent:0 event:0 context:0 transferred:0
– validate
– state check: ok
CIFace: Sent CRequest@3dd3570 RequestRouteCall-URServer_P_[820]/4833323
– created NAData fbb2310
FinishRequest CRequest@3dd3570 RequestRouteCall-URServer_P_
[820]/4833323
IFace stats: q=0 s=0
– complete
– NAData ClRq removed
TNAEmulator::NotifyBackup()
@16:27:35.9940 [BSYNC] Trace: Send to backup (SIPServer_B_*****) [852]:
message EventUserEvent
attr_#1005 0
attr_#1004 994
attr_#1003 1471958855
attr_#1002 2294735
attr_#1001 5
attr_#1000 131072
AttributeAgentWorkMode 0 (Unknown)
AttributeAgentStateReasonUnused 1
@16:27:35.9940 [BSYNC] Trace: Sent
16:27:35.994: RID:CUUID>4833323:4I61R0DBQD48L514OGJQEPMOPK001GDI:
16:27:35.994: IncrementRouteRequestCounter, option 100
16:27:35.994: $*:CTI:SIP:ROUTE_CALL:804305
16:27:35.994 — CIFace::Request —
16:27:35.994: $-TLIB:CTI:Unknown:0:198
16:27:35.994: $+SIP:CTI:PARTY_STATE_CHANGED:4117171:121
16:27:35.994: routing dialog ‘19215842’ terminated
16:27:35.994: Adding OtherTrunkName(RU_UCPGW01_INTERNATIONAL_Trunk): done
16:27:35.994 – thisCall by party
16:27:35.994 SetContext: for party 4901.b4ae580-4cdc710:1
16:27:35.994 +++ CIFace::Event +++
+++ Pre-event +++
Type EventReleased
Devices: <4901/4901> <-/74995860011> <-/->
Calls: 17748505/037a028a722620fa/17748505.4cdc710/c:2/r:6 0/none
Parties: D4901/4901.b4ae580-4cdc710:1/l:3/r:2/Queued,RtRequest,Destination
X74995860011/74995860011.b4b1280-4cdc710:1/l:1/r:0/Established,Origination
none
Cause: SwitchTerminated/54, Info: 0
Flags: divert=0 hook=1 postCall=0 active=1 moveAll=1 callType=1 hideOtherPi=0 InternalOther=0
— Pre-event —
+++ Released +++
– route: call disconnect
SetRouteEnd: party 4901.b4ae580-4cdc710:1, cause SwitchTerminated
) [852]:
message RequestSetDNInfo
‘RTR’ 886
@16:27:35.9940 [0] 8.1.102.35 distribute_response: message EventRouteUsed
AttributeEventSequenceNumber 0000000000f40676
AttributeTimeinuSecs 994000
AttributeTimeinSecs 1471958855 (16:27:35)
AttributeExtensions [75] 00 02 00 00..
‘OtherTrunkName’ ‘********UCPGW01_INTERNATIONAL_Trunk’
‘BusinessCall’ 1
‘RTR’ 886
