Stats are Shown as NA -- Issue solved
Team,
In CCPulse application all the stats are showing as NA. How to solve this issue. Kindly looking forward for your solutions.
Check your statserver state and configuration
As above, plus;
Make sure your copy of CCPulse is pointing to the right StatServer - or, in fact, that it is connected to any StatServer! :slight_smile:
this may also explain some of your other stats issues, fix ccpulse first
Thanks for your reply. After adding the host name in the HOST file. All the stats in the CCPulse is working fine.
Thanks for letting us know. Please update the Subject heading with " - Solved"
I’m hoping this is a lab environment? If not, you really need to figure out why you weren’t able to resolve the host name using DNS.
Seconded. Otherwise, every local install you make of CCPulse will need a Host File tweak…
