[SOLVED] CCPulse 7.5 wizards buttons disabled using a superadmin access.
Hi all, as in subject if I use a super administrator login, I can do everything, but can’t use wizards in CCPulse (template wiz., import/export, etc.), 'cause they are greyed out.
http://web.tiscali.it/modifiche/ccpulse_0001.png
Regards.
check your object permission in the security tab of your CCPulse application, it may only have read only access
You need the RANK CCP Administrator on the person object in CME.
It has nothing to do with access groups.
Thx guys, I’ll check.
G.
sweeeet… was the “ccp admin rank” in person; all working as a charm. Thanks a lot Catanirex.
