Can anyone clarify why shift swap approvals are timing out when agents from different org units trade shifts? The standard workflow works, but cross-unit swaps fail with a 500 error after 30s. We are using the default WFM settings in Genesys Cloud. Here is the relevant config snippet:
it depends, but generally that 500 isn’t from wfm. check if the agent profiles have the right permissions for cross-tenant data access. the sdk won’t throw a 500 on a simple swap unless the backend routing fails.
I usually solve this by bypassing the standard WFM UI for debugging and hitting the POST /api/v2/workforcemanagement/businessunits/{businessUnitId}/shifttrading/trades/evaluate/jobs endpoint directly. The 500 error is rarely a timeout on the swap logic itself. It’s almost always a serialization issue when the backend tries to resolve cross-tenant user attributes.
check your payload structure. if require_manager_approval is true, the system attempts to fetch the manager’s contact details. if that manager is in a different org unit without proper sharing settings, the internal service call fails hard. you’ll see this in the x-request-id header logs.
try querying the aggregate data for the swap period to see if the user IDs resolve correctly first.
if the manager lookup fails, the swap request hangs until the gateway times out. disable require_manager_approval temporarily to isolate the auth chain.
the 500 happens because the backend can't resolve the cross-tenant manager ID automatically. you have to inject it explicitly before posting the shift trade.
check the user profile endpoint first. it's usually a simple lookup missing.
