ServiceNow Webhook Payload Truncation on High-Volume SMS Inbound Flows
I’m trying to figure out why the JSON payload sent from Genesys Cloud to our ServiceNow instance via Data Actions appears to be truncating the conversation context when the inbound SMS volume exceeds 200 messages per minute. The integration works flawlessly during low-load periods, but under stress, the text field in the ServiceNow incident creation record cuts off at exactly 1024 characters, despite the original message being longer. This is causing critical context loss for our tier-2 support agents who rely on the full transcript for triage.
Here is the current configuration and reproduction path:
  1. Inbound SMS triggers an Architect flow that captures the full message body into a flow variable.
  2. A Data Action is invoked to POST to the ServiceNow REST API endpoint /api/now/table/incident.
  3. The payload includes standard fields (caller_id, short_description) and the custom u_gc_transcript field populated with the flow variable.
  4. The Genesys Cloud logs show the full payload being sent successfully with a 201 Created response from ServiceNow.
  5. However, the resulting incident in ServiceNow shows the transcript truncated at the 1024-character mark.
We have verified that the ServiceNow field length is set to 64KB, so this is not a schema limitation on the target side. We are currently using the Genesys Cloud v2 API for the webhook trigger. Is there a known payload size limitation within the Genesys Cloud Data Action execution engine itself, or is this potentially a serialization issue with the JSON encoder when handling high-throughput events? We have also checked the Content-Length header in the outbound request, which correctly reflects the full message size before truncation occurs in the database. Any insights into whether this is a platform-level buffer overflow or a misconfiguration in the Data Action mapping would be appreciated. We are considering switching to a batched approach via a queue, but want to rule out immediate configuration fixes first.
TL;DR: The truncation is a ServiceNow input validation limit, not a Genesys Cloud export failure. Flatten the JSON payload in the Data Action to bypass deep nesting rejection.
Ah, this is a known issue with ServiceNow data actions handling large conversation contexts. The 1024-character cut-off is rarely a Genesys Cloud limit. It is usually the ServiceNow sys_properties or the specific incident field definition rejecting deep JSON nesting during high-throughput events.
When SMS volume spikes, the webhook payload size increases. ServiceNow often drops or truncates the body if the JSON structure is too complex or if the total byte count exceeds their default webhook handler limits.
The fix is to flatten the JSON payload in the Genesys Cloud Data Action configuration. Do not send the entire conversation object. Map only the essential fields: caller_id, disposition_code, and a truncated message_preview.
Here is a recommended transformation for the Data Action:
 "incident": {
 "caller_id": "{{contact.attributes.phone_number}}",
 "short_description": "SMS Alert: {{contact.attributes.first_message}}",
 "description": "Context: {{contact.attributes.message_history}}",
 "priority": 3
Ensure the description field in ServiceNow is set to unlimited length. If the truncation persists, check the ServiceNow sys_properties for glide.webhook.max_payload_size. Increase this value if allowed by your security policy.
Also, verify the Genesys Cloud region settings. EU-West instances sometimes have stricter outbound payload limits for compliance. If the payload exceeds 1MB, Genesys may drop the webhook entirely. Monitor the Data Action logs for 400 Bad Request errors. These errors confirm the truncation happens at the receiver end.
For legal discovery purposes, do not rely on ServiceNow for full conversation text. Use the Bulk Export API to S3 instead. This ensures chain of custody and full metadata retention. ServiceNow should only hold the reference ID.
