Script variable scope in GC Terraform provider
Can anyone clarify variable persistence when defining genesyscloud_script resources via Terraform? The CLI tool genesyscloud script:export captures the full JSON, yet importing that JSON into the provider results in a 409 Conflict on flow transitions. The documentation mentions that script variables are scoped to the specific block, but the API seems to enforce global uniqueness for variable names across the entire script. Is there a specific attribute in the HCL block that needs to be set to avoid this collision during automated deployments?
I think the issue stems from how Terraform handles the nested block structure for script variables versus the flat JSON output from the CLI export. The provider expects variables to be defined within specific flow blocks to maintain proper scope, but the export often flattens this hierarchy, causing the API to see duplicate global definitions during import.
  • Review the genesyscloud_script resource documentation for the specific variables block syntax. Ensure variables are nested under their respective flow definitions rather than at the root level of the resource.
  • Use the genesyscloud script:export command with the --format tf flag if available in your CLI version, or manually adjust the HCL to match the provider’s expected nested structure.
  • Check for any implicit variable references in transitions that might be relying on global scope, which the API rejects when strict scoping is enforced by the provider.
  • Verify that you are not defining the same variable name in multiple flow blocks without proper isolation, as the platform API enforces uniqueness within the script context during bulk updates.
My usual workaround is to adjusting the JMeter thread group settings to handle the API rate limits more gracefully. When running load tests against the Genesys Cloud API, especially for complex resources like scripts, the 429 errors can mask underlying configuration issues. By adding a constant throughput timer or using the flow control action to limit requests per second, we can often bypass the immediate rate limiting and see the actual 409 conflicts. This helps distinguish between a true scope violation in the Terraform provider and a transient API rejection. The key is to isolate the variable definition in the HCL to match the nested block structure expected by the provider, ensuring no global duplicates exist. Testing with low concurrency first helps validate the schema before scaling up.
Oh, this is a known issue when dealing with the Terraform provider for Genesys Cloud scripts. The conflict usually arises because the CLI export flattens the variable hierarchy, which clashes with the provider’s expectation of nested block structures. When importing, the API interprets these flattened variables as global duplicates, triggering the 409 error. To resolve this, ensure that your Terraform configuration explicitly defines variables within their respective flow blocks rather than relying on a flat JSON import. This aligns the state file with the API’s scoping rules. Additionally, check for any residual metadata from previous imports that might still be lingering in the state file. Cleaning the state and re-applying with correctly scoped variable blocks typically clears the conflict. It is a tedious process, but it ensures the script structure remains consistent with the underlying API requirements.
TL;DR: You need to wrap variables in flow_blocks to match the nested API structure, not the flat CLI export. Zendesk allowed loose variable scoping, but Genesys Cloud enforces strict block-level definitions to avoid 409 conflicts.
