Hi i have been asked by my current employer to review the routing setup as they suspect that the previous integrator didnt design the flow in the best way.
I can design routing strategies etc but i am not a expert. I just wanted to know if there was anything to avoid in routing when it comes to Best Practices or anything that would help with performance?
Mike -
Many of the same principles used in programming can be used here. A few things to consider:
Do some of the existing strategies use the same (or almost the same) routines/block of steps in certain places? If so, you might be able to move this block to a subroutine
Do some of the strategies use essentially the same routing, but the only difference is the targets and/or treatments? If so, combine the strategies and do the customization with database lookups or list objects
Is there a standard for variable /target naming conventions?
Is there a lot of hard coding for targets, treatments, etc? Can this be modified so the strategy uses more data lookups than explicit declaration?
What is the reason for the 100+ VQs? If some of them have similar attributes, could they be combined, and filters used to provide additional reporting?
For example, if you had VQ_QUEUE, VQ_QUEUE_RED, and VQ_QUEUE_GREEN, could you whittle it down to just VQ_QUEUE, and apply Filters to gather Red and Green statistics?
Good luck. Our original integrator did the same thing - created a bunch of similar strategies where the only things that changed was the target and the Virtual queue. Over the years, we’ve reworked our routing, to where we have a single core routing strategy (with about 60 supporting subroutines) that is data driven and supports 95% of our routing.
I can undersign all recommendations in previous posts but these are focused mainly on voice routing. If we’re talking about email routing then I would focus on the main point and that is workflow. Many people (routing designers) underestimate that when designing routing of emails and to be honest I did the same mistake when doing it for first time few years ago. So being in your role I would analyse/describe implemented workflow in the first step, compare it with required one in second step and propose some optimization afterwards.
About number of VQs - it’s hard to say without knowledge of reporting requirements. Personally, I prefer using filters but it could have some “negative” impact to required time for development/modification of historical reports especially when using CCA.
