Does anyone have ideas on how to use URS to route a call to an external number ie mobile phone?
That should be pretty simple just have URS place a call to it!
All you need to do is defne the number in singlequote paranthesis and you are set. We had a client who wanted to place outbound calls with URS on Nortel and we set him up in less then two days.
I think pretty soon someone should think about creating an outbound dialer using URS only! Of course, we will need a physical call coming from somewhere, but I am sure there is a way we can combine URS with Custom Server to control Dialogic card, or even PBX itself.
Do you want to route to the same number each time or to a variable? both methods are similar by using the TRoute function in IRD. If the number is fixed enter it as the ‘destination’, set the Route type to RouteTypeUnknown. If the number changes define the number you want to call as a variable earlier in the strategy, then, in the destination field click on the variable name (will be part of a drop down menu).
Hope this helps
Thx guys I have tried that already but it won’t dial the number.
Here is some of my ts log:
@20:05:06.4177 [0] 6.5.202 distribute_event: message EventRouteRequest
AttributeTimeinuSecs 417717
AttributeTimeinSecs 1052334306 (20:05:06)
AttributeOtherQueue '4002'
AttributeThisQueue '4002'
AttributeOtherDNRole 1
AttributeOtherDN '8139'
AttributeThisDNRole 2
AttributeThisDN '4002'
AttributeDNIS '4002'
AttributeConnID 000000f9631c5fab
AttributeCallID 2331
AttributeCallType 1
@20:05:06.4210 [0] Received from 13 (0003 urs_6510700): message RequestRouteCall
AttributeOtherDN '907710468183'
AttributeExtensions [27] 00 01 00 00..
'CUSTOMER_ID' 'Resources'
AttributeRouteType RouteTypeUnknown
AttributeReferenceID 26457
TESTLV2: ts>route[CRV=1 <=> CRV=58]>link[1]
** ts6.5.202[1] ** 20:05:06.4213
08 00 00 22 08 02 80 58 62 96 1C 1A 91 A1 17 02 01 64 02 01 B7 40 0F 70 0D 80 39 30 37 37 31 30 34 36 38 31 38 33
=== parsed message ===
prot_discr = 8
CRV = 8058
MsgType = 98 (FACILITY)
Facility: serv_discr = 17(q932_suppl) fac_ie = component_tag = A1(INVOKE)
invoke_id tag: 02, value = 100
operation tag: 02, value = 183(RouteSelect)
params = q931_tag = 40
list =
Called_Party_Number: type_plan = 0(unknown) address = 907710468183
** link[1] ** 20:05:06.4701
08 02 00 58 5A 96 1C 0F 91 A1 0C 02 01 01 02 01 B9 40 04 08 02 81 9C
prot_discr = 8
CRV = 58
MsgType = 90 (RELEASE COMPLETE)
operation tag: 02, value = 185(RouteEnd)
list =
Cause: code_std_loc = 1(CCITT_PubNetLocUsr) cause = 28(C_INVLDNUM C_COV_DONT_ANS)
TESTLV2: link[1]>routeCRV[0x0058 <=> 0x0001]>ts
@20:05:06.4706 [0] 6.5.202 distribute_response: message EventRouteUsed
AttributeTimeinuSecs 470667
AttributeCallState 3
AttributeThirdPartyDNRole 2
AttributeThirdPartyDN '907710468183'
AttributeExtensions [18] 00 01 01 00..
'G3Cause' 600
AttributeCallType 1
Wed May 07 20:05:06 2003.471 Trace donald LucentG3 GCTI04542 Message EventRouteUsed sent to 13 ( regular urs_6510700 )
sent to 13 (0003 urs_6510700)
Wed May 07 20:05:06 2003.471 Trace donald LucentG3 GCTI04542 Message EventRouteUsed sent to 16 ( regular statserver_cca )
sent to 16 (0bf6 statserver_cca)
Wed May 07 20:05:06 2003.471 Trace donald LucentG3 GCTI04542 Message EventRouteUsed sent to 15 ( regular statserver_main )
sent to 15 (05c7 statserver_main)
PARTIES:
Call_info: call_id 2331, conn_id 000000f9631c5fab, assoc 0xec7 Internal
VDN=4002 routed_to=907710468183
8139, role 1, state OH+(Dialing), id=1, Created:1052334304
4002(queue), role 2, state QS+(RouteUsed), queue=4002, Created:1052334304
TESTLV2: Party found: party_id = 1, DN = 8139
@20:05:06.4740 [0] 6.5.202 distribute_event: message EventReleased
AttributeTimeinuSecs 474012
AttributeCallState 0
AttributeOtherDNRole 2
AttributeOtherDN '4002'
AttributeThisDNRole 1
AttributeThisDN '8139'
AttributeCallType
PARTIES:
8139, role 1, state DELETED+OH+(Released), id=1, Created:1052334304
Can you dial that number exactly from a physical set? ( on the same side of the PBX as Genesys)
It’s cool it was the COR on the switch for the RP I was using. Damn switch guys told me everything was ok with the COR. Always check yourself is the rule I think!
Thx for the advice though.
