i’m testing it since days and now i share with you my experiences. Well, i have an avi video file. (Converted from FLV).
First, i must extract the audio track from the avi file. Its easy, i use the following command:
mplayer sample.avi -ao pcm outputfilename.wav -vc null -vo null
Next step, converting this wav file to 8kHz 16bit mono stream. Then i rename this file to pcmu.wav
Now i’d like to create a H.263 video stream. I can use different picture sizes, CIF, or QCIF. I need CIF settings.
Converting the avi file to H.263 CIF format with 15FPS i will use mencoder. The command looks like:
mencoder sample.avi -vf scale=352:288 -of rawvideo -ofps 15000/1001 -nosound -o h263_CIF=2 -ovc lavc -lavcopts vcodec=h263:keyint=10:vpsize=1000:vqmin=3:vbitrate=100
352:288 means CIF size, 15000/1001 means 15FPS which is option 2 in filename. (Option 1=30FPS)
Then i will use smzip to compress theses files (pcmu.wav & h263_CIF=2) into an archive file.
smzip -ac all 10.zip pcmu.wav h263_CIF=2
I must use in the name of the zip file numbers only. Next step is copy this file into the announcement folder under Stream Manager. In the routing strategy i use play announcement block to play this video on a routing point.
It works! But… but i’d like to use H.264 video. Lets see the steps:
Audio extracting is the same method. Lets convert some video in H.264 format! Its good to know how it should work. I tried many formats, but it doesnt work.. :‘( :’( :‘( :’(
If i’d like to convert into CIF, 15FPS with profile-level-id=2
mencoder.exe sample.avi -vf scale=352:288 -of rawvideo -ofps 15000/1001 -nosound -o h264_42e014=2 -ovc x264 -x264encopts keyint=10:bframes=0:nob_adapt:nocabac:level_idc=20
I tried an another method too:
mencoder.exe sample.avi -vf scale=352:288 -of rawvideo -ofps 15000/1001 -nosound -o h264_42e014=2 -ovc x264 -x264encopts subq=6:keyint=25:bframes=0:nob_adapt:nocabac:level_idc=20
Then compress it with the pcmu.wav into an archive, but i receive only the sound of the video. :‘( :’(
It works, when i call the routing point from inside with the Counterpath bria softphone, but i use trunk DN -s to another gateways, and only the H263 video works properly.
I tried it with variable formats:
CIF with 15 or 30FPS : 42e00c, 42e00d, 42e014, 42e015, 42e016
Can anybody help me?
best regards, Alex
