Reporting Analytics and Aggregation - UserData Mapping Issues
  1. I’m unable to map User Data to Queue based Hierarchies (H_QUEUE, H_QUEUE_GRP, H_QUEUE_ABN, H_QUEUE_ACC). I’m unable to measure a particular call type entered in a particular queue. which was possible in CCPulse+ reports and CCA.
  2. Whether RAA is restricted to map only 2 custom dimension tables (upto 10 low cardinality data). What if i need to see aggregated results for more than 10 KVPs?
What algorithm you are implementing.
I’m trying to configure Genesys Reporting Analytics and Aggregates. From RAA User Guide, user data mapping cannot be done for H_Queue Hierarchies. Also, in RAA Reference Manual, AG2_Queue_* doesnt have reference to Interaction_Descriptor table or User defined Dimension Tables (USER_DATA_KEYS1 or 2)
Do you mean user data mapping via .ss file under RAA root instalation directory?
Yes
user data mapping .ss file doesnt allow me to add user data mapping to H_QUEUE hierarchy and not more than 2 Custom defined attached data dimension tables.
H_QUEUE is not possible,you can use H_AGENT_QUEUE.
there are 2 documented restrictions for RAA customization: 1) you cannot create custom aggregation for the H_QUEUE hierarchy and 2) you can only add 2 custom dimension tables to the RAA customization, which means you can have up to 10 custom low cardinality data included in GIM aggregate tables.
no workaround on for these restrictions.
