Has anybody develop a stored procedure to purge data from the CC Analyzer historical tables?
drop user will do the trick ![]()
Interesting question, because I was trying to do it as well, and right away I thought of ETL Assistant. You can specify how long you want to keep the data for, and when you would want to truncate it.
Thanks…
Any time
Tell me if there is anything else I can help you with.
I believe Genesys have a utility to purge the data.Rumour has it it’s on the Reporting CD I’m not in a position to check at the moment.
