Problems with Hyperion Interactive Reporting 11
Hi guys,
I have a problem with my Hyperion Reports. Recently my costumer had new needs and I created new statistics using DMA and synchronized them with Datamart.
In datamart i can see the new columns however i can’t see the same columns on Hyperion, so i can’t create new tables using those statistcs.
Is there any option in Hyperion to synchronized Tables or Views?
I thought that when i create new statistics in DMA they appeared automatically in the Hyperion Query.
If not remember bad double click the Query tables and there is a button to synchronize columns. You would then have to add to the view. How you expect to hyperion or any other BI would know what you want to do with the columns?
I assume you mean you can’t see the new tables in Hyperion?
They will be visible in the bottom left Elements section of the Hyperion GUI. You can then drag them to existing or new Queries.
