I have some problem when I try to add a media in Genesys Internet suite 5.1.6. Is there anyone who could send me , the files he made to add a media (the test of the fax for example?) and the paths he used to place those files? Or a good explaination?
we tried it last year too. First thing is that FAX example is impossible to follow (at least it did not make any sense to me)
I was able to create a little program called “MediaKiller” ( don’t ask me why I called that!), and it would connect to MediaLink and register itself as such.
The problem I encountered was actually trying to connect to ContactServer. I could not even understand ActiveX example nor find the class they were talking about there.
So, the project just got stuck, because without a connection to Contact Server, there is no way to retrieve all the info unless I look directly in MediaLink database, and I figured that I should just wait for something better to come…
I know it does not tell you much, but try contacting GS and see if they can help you. Chances are they will tell you that it is handled by PS.
