Problem to get reports in Hyperium.
Hi everyone
I have delay in obtaining the data to get reports in Hyperium even when the DMA reads are Ok.
I see the ETL logs and I don´t find any explication of this. :-[
this ever happened to anyone?
no body happend that ??
What is the delay you are talking about and for which aggregation level?
Usually the ETL is set to transfer data as soon as possible but the aggregation process could be set to be run every hour or even once a day. I would recommend you to check the ETL configuration options.
e.
More information required.
