Problem Accessing GAX "HTTP error 404"
Hello All,
I have installed GAX version 8.5 as per the steps provided in the deployment guide using command line mode. SCI allows me to start gax instance, After starting through SCI when i try to access GAX using url:http://localhost:9999/gax. It throws a error “http error 404”. I do not see any error in logs except except “Listener failed to load schema for asd” and “Host_Status_Unavailable”. One thing i have noticed after installation and starting GAX instance. Two folders should have been generated “gaxLocalCache” & “installation” under folder GCTI\GAX\Plugin-data\asd. I can see only gaxlocalcache folder but that too its empty & installation folder itself is not generated. Hence genesys_silent_ini file is also missing. Hope it makes some sense to you.
I am not using default port 8080 to launch GAX, since tomcat is using port 8080.
Request your help.
Rajnish
Try to reinstall GAX it seems the installation is corrupted
Access to DB is Ok?
Well no DB related error in the logs. I am using DAP ponting to Oracle DB (JDBC connection with role= main) and same is added under connection tab of GAX_application. I have created GAX_DAP with out any DB server and DB details are also correct in the DB info tab of dap.
Rajnish
Try reinstall and post install logs here
Please find below GAX log:
Genesys Administrator Extension Log File
Version: 8.5.000.91
2016-01-20 12:05:12,233 WARN : com.genesyslab.gax.core.audit.AuditDatabaseBeanManager [main] - [49] Auditing data source is not configured, auditing is disabled!
2016-01-20 12:05:13,179 INFO : com.genesyslab.gax.core.configuration.messageserver.MessageServerAdapter [main] - [180] ------------------------------------------------------------
2016-01-20 12:05:13,179 INFO : com.genesyslab.gax.core.configuration.messageserver.MessageServerAdapter [main] - [181] GAX - MS configuration.
2016-01-20 12:05:13,243 ERROR: com.genesyslab.gax.core.configuration.messageserver.MessageServerAdapter [main] - [187] No MS server found
2016-01-20 12:05:13,264 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [180] ------------------------------------------------------------
2016-01-20 12:05:13,264 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [181] GAX - LCA configuration.
2016-01-20 12:05:13,861 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [202] Timeout in seconds between attempts = 60
2016-01-20 12:05:13,861 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [207] Timeout for LCA = 1000
2016-01-20 12:05:13,862 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [219] Maximum number of connection attempts = 1
2016-01-20 12:05:13,862 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [222] Maximum number of configured switchovers trials = unlimited
2016-01-20 12:05:13,871 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [236] Starting Warmstandby Service
2016-01-20 12:05:13,871 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [238] Warmstandby Service started.
2016-01-20 12:05:13,871 DEBUG: com.genesyslab.gax.core.configuration.warmstandby.utils.GaxWarmStandbyListener [com.genesyslab.PCT.invoker.warmstandby] - [36] WarmStandby changed state to Idle.
Endpoint uri: tcp://LCA@localhost:4999
State:Closed
2016-01-20 12:05:13,934 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [180] ------------------------------------------------------------
2016-01-20 12:05:13,934 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [181] GAX - SCS configuration.
2016-01-20 12:05:13,990 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [202] Timeout in seconds between attempts = 60
2016-01-20 12:05:13,991 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [219] Maximum number of connection attempts = 1
2016-01-20 12:05:13,991 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [222] Maximum number of configured switchovers trials = unlimited
2016-01-20 12:05:14,005 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [236] Starting Warmstandby Service
2016-01-20 12:05:14,005 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [238] Warmstandby Service started.
2016-01-20 12:05:14,014 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [155] Opening connection to SCS Server …
2016-01-20 12:05:14,021 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [155] Opening connection to LCA Server …
2016-01-20 12:05:14,035 DEBUG: com.genesyslab.gax.core.configuration.warmstandby.utils.GaxWarmStandbyListener [com.genesyslab.PCT.invoker.warmstandby] - [36] WarmStandby changed state to Idle.
Endpoint uri: tcp://SCS@10.9.111.80:3600
State:Opening
2016-01-20 12:05:14,040 WARN : com.genesyslab.gax.core.system.SystemConfigurationImpl [main] - [145]
GAX starts with following command line:
-host frdwgeap01d.dev.invitrogen.net -port 2020 -app “GAX_New_8.5.103”
GAX (application dbid: 482) is configured with the following options:
arm/delete_from_db_after_processing: ‘false’
arm/local_announcement_folder: ‘announcement’
arm/local_music_folder: ‘music’
arm/local_os: ‘RHEL5’
arm/local_path: ‘/opt/gax/arm’
arm/local_sox_path: ‘/usr/bin/sox’
arm/target_announcement_folder: ‘announcement’
arm/target_music_folder: ‘music’
arm/target_os: ‘RHEL5’
arm/target_path: ‘/mnt/arm/target’
asd/local_ip_cache_dir: ‘./plugin.data/asd/gaxLocalCache’
asd/silent_ini_path: ‘./plugin.data/asd/installation/genesys_silent_ini.xml’
ezpulse/access_url: ‘http://frdwgysapp03d.dev.invitrogen.net:9999’
ezpulse/health_expire_timeout: ‘30’
ezpulse/pause_timeout: ‘0’
ga/ga_appname: ‘default’
ga/ga_host: ‘’
ga/ga_port: ‘80’
ga/ga_protocol: ‘http’
general/auditing: ‘true’
general/client_app_name: ‘default’
general/default_account_dbid: ‘100’
general/inactivity_timeout: ‘600’
general/msgsrv_attempts: ‘1’
general/msgsrv_max_switchovers: ‘-1’
general/msgsrv_timeout: ‘10’
general/msgsrv_warmstandby_timeout: ‘60’
general/scs_attempts: ‘1’
general/scs_max_switchovers: ‘-1’
general/scs_timeout: ‘10’
general/scs_warmstandby_timeout: ‘60’
general/session_timeout: ‘900’
log/all: ‘D:\GCTILogs\gax_8.5.103\GAX_8.5.103’
log/standard: ‘’
log/trace: ‘’
log/verbose: ‘all’
opm/write_json: ‘false’
pulse/cache_expire_timeout: ‘1200’
pulse/editable_templates: ‘false’
pulse/install_templates: ‘true’
pulse/max_widgets_per_user: ‘0’
pulse/snapshot_expire_timeout: ‘24’
2016-01-20 12:05:14,105 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [180] ------------------------------------------------------------
2016-01-20 12:05:14,105 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [181] GAX - SCS configuration.
2016-01-20 12:05:14,167 DEBUG: com.genesyslab.gax.core.scs.SCSConnector [coreExecutor-1] - [80] SCS and CS connection monitoring activated.
2016-01-20 12:05:14,223 DEBUG: com.genesyslab.gax.core.configuration.warmstandby.utils.GaxWarmStandbyListener [com.genesyslab.PCT.invoker.warmstandby] - [51] WarmStandby switched channel to tcp://SCS@10.9.111.81:3600.
WarmStandby state: Waiting
Channel state: Closed
2016-01-20 12:05:14,223 DEBUG: com.genesyslab.gax.core.configuration.warmstandby.utils.GaxWarmStandbyListener [com.genesyslab.PCT.invoker.warmstandby] - [36] WarmStandby changed state to Waiting.
Endpoint uri: tcp://SCS@10.9.111.81:3600
State:Closed
2016-01-20 12:05:14,556 DEBUG: com.genesyslab.gax.core.configuration.warmstandby.utils.GaxWarmStandbyListener [com.genesyslab.PCT.invoker.warmstandby] - [36] WarmStandby changed state to Reconnecting.
State:Closed
2016-01-20 12:05:14,576 INFO : com.genesyslab.gax.core.configuration.lca.LcaChannelListener [Thread-12] - [23] Event:Channel tcp://LCA@localhost:4999 is opened.
2016-01-20 12:05:14,578 INFO : com.genesyslab.gax.core.configuration.lca.LcaChannelListener [Thread-12] - [28] Event:updateStatus app name: GAX_New_8.5.103
2016-01-20 12:05:14,578 INFO : com.genesyslab.gax.core.configuration.lca.LcaChannelListener [Thread-12] - [29] Event:updateStatus status: Running
2016-01-20 12:05:14,597 INFO : com.genesyslab.gax.core.configuration.scs.SCSConnectorChannelListener [Thread-11] - [30] Event:Channel tcp://SCS@10.9.111.81:3600 is closed.
2016-01-20 12:05:14,780 DEBUG: com.genesyslab.gax.core.configuration.warmstandby.utils.GaxWarmStandbyListener [com.genesyslab.PCT.invoker.warmstandby] - [36] WarmStandby changed state to Idle.
State:Opened
2016-01-20 12:05:14,780 INFO : com.genesyslab.gax.core.configuration.scs.SCSConnectorChannelListener [Thread-13] - [22] Event:Channel tcp://SCS@10.9.111.81:3600 is opened.
2016-01-20 12:05:14,780 DEBUG: com.genesyslab.gax.core.web.notification.CometEventService [Thread-13] - [82] Channel created: /core/scs
2016-01-20 12:05:14,780 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [Thread-13] - [52] CometD: Number of Subscribers=0
2016-01-20 12:05:14,796 DEBUG: com.genesyslab.gax.core.scs.NotificationService [Thread-13] - [34] Publishing message into channel /core/scs:
{“msgtype”:“Connection”,“state”:“Opened”}
2016-01-20 12:05:14,796 DEBUG: com.genesyslab.gax.core.scs.SCSConnector [coreExecutor-1] - [88] SCS connector initialization activated
2016-01-20 12:05:14,920 DEBUG: com.genesyslab.gax.core.scs.CommunicationService [coreExecutor-1] - [175] Subscribed to AlarmCondition objects in SCS
[ 117 115 116 101 102 103 104 105 109 110 111 112 113 114 118 ]
2016-01-20 12:05:16,609 WARN : com.genesyslab.gax.core.database.GAXOracleDataSource [Thread-15] - [36] Reconnect to database for core
2016-01-20 12:05:16,609 WARN : com.genesyslab.gax.core.database.GAXOracleDataSource [Thread-19] - [36] Reconnect to database for asd
2016-01-20 12:05:16,609 WARN : com.genesyslab.gax.core.database.GAXOracleDataSource [Thread-18] - [36] Reconnect to database for opm-arm
2016-01-20 12:05:16,625 WARN : org.hibernate.util.JDBCExceptionReporter [Thread-19] - [233] SQL Error: 12514, SQLState: 66000
2016-01-20 12:05:16,625 WARN : org.hibernate.util.JDBCExceptionReporter [Thread-18] - [233] SQL Error: 12514, SQLState: 66000
2016-01-20 12:05:16,625 WARN : org.hibernate.util.JDBCExceptionReporter [Thread-15] - [233] SQL Error: 12514, SQLState: 66000
2016-01-20 12:05:16,625 ERROR: org.hibernate.util.JDBCExceptionReporter [Thread-15] - [234] Listener refused the connection with the following error:
ORA-12514, TNS:listener does not currently know of service requested in connect descriptor
2016-01-20 12:05:16,625 WARN : com.genesyslab.gax.core.util.CoreDatabaseInspectorImpl [Thread-15] - [94] Failed to load database schema version for core
2016-01-20 12:05:16,625 ERROR: org.hibernate.util.JDBCExceptionReporter [Thread-19] - [234] Listener refused the connection with the following error:
2016-01-20 12:05:16,625 ERROR: org.hibernate.util.JDBCExceptionReporter [Thread-18] - [234] Listener refused the connection with the following error:
2016-01-20 12:05:16,625 WARN : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-18] - [94] Failed to load database schema version for opm-arm
2016-01-20 12:05:16,625 WARN : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-19] - [94] Failed to load database schema version for asd
2016-01-20 12:05:16,625 WARN : com.genesyslab.gax.core.database.GAXOracleDataSource [Thread-15] - [36] Reconnect to database for core
2016-01-20 12:05:16,640 WARN : com.genesyslab.gax.core.database.GAXOracleDataSource [Thread-18] - [36] Reconnect to database for opm-arm
2016-01-20 12:05:16,640 WARN : com.genesyslab.gax.core.database.GAXOracleDataSource [Thread-19] - [36] Reconnect to database for asd
2016-01-20 12:05:16,640 WARN : org.hibernate.util.JDBCExceptionReporter [Thread-15] - [233] SQL Error: 12514, SQLState: 66000
2016-01-20 12:05:16,640 ERROR: org.hibernate.util.JDBCExceptionReporter [Thread-15] - [234] Listener refused the connection with the following error:
2016-01-20 12:05:16,640 WARN : com.genesyslab.gax.core.util.CoreDatabaseInspectorImpl [Thread-15] - [94] Failed to load database schema version for core
2016-01-20 12:05:16,640 WARN : com.genesyslab.gax.core.util.CoreDatabaseInspectorImpl [Thread-15] - [47] Db Schema Version for plugin gax-core 8.1.301.01 is not matching the current Db Version for PluginSummary in the Database: null !!!
2016-01-20 12:05:16,640 INFO : com.genesyslab.gax.core.util.CoreDatabaseInspectorImpl [Thread-15] - [50] ------------------------------------------------------------------------
2016-01-20 12:05:16,640 ERROR: com.genesyslab.gax.core.plugin.DefaultPluginManagerImpl [Thread-15] - [165] Plugin gax-core database schema version mismatch
2016-01-20 12:05:16,640 WARN : org.hibernate.util.JDBCExceptionReporter [Thread-18] - [233] SQL Error: 12514, SQLState: 66000
2016-01-20 12:05:16,640 WARN : org.hibernate.util.JDBCExceptionReporter [Thread-19] - [233] SQL Error: 12514, SQLState: 66000
2016-01-20 12:05:16,640 ERROR: org.hibernate.util.JDBCExceptionReporter [Thread-18] - [234] Listener refused the connection with the following error:
2016-01-20 12:05:16,640 ERROR: org.hibernate.util.JDBCExceptionReporter [Thread-19] - [234] Listener refused the connection with the following error:
2016-01-20 12:05:16,640 WARN : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-18] - [94] Failed to load database schema version for opm-arm
2016-01-20 12:05:16,640 WARN : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-18] - [47] Db Schema Version for plugin gax-opm-arm 8.1.301.01 is not matching the current Db Version for PluginSummary in the Database: null !!!
2016-01-20 12:05:16,640 WARN : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-19] - [94] Failed to load database schema version for asd
2016-01-20 12:05:16,640 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-18] - [50] ------------------------------------------------------------------------
2016-01-20 12:05:16,640 WARN : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-19] - [47] Db Schema Version for plugin gax-asd 8.5.000.01 is not matching the current Db Version for PluginSummary in the Database: null !!!
2016-01-20 12:05:16,640 ERROR: com.genesyslab.gax.core.plugin.DefaultPluginManagerImpl [Thread-18] - [165] Plugin gax-opm-arm database schema version mismatch
2016-01-20 12:05:16,640 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-19] - [50] ------------------------------------------------------------------------
2016-01-20 12:05:16,640 ERROR: com.genesyslab.gax.core.plugin.DefaultPluginManagerImpl [Thread-19] - [165] Plugin gax-asd database schema version mismatch
2016-01-20 12:05:17,070 DEBUG: com.genesyslab.gax.core.scs.CommunicationService [coreExecutor-1] - [175] Subscribed to Application objects in SCS
[ 219 242 100 310 325 383 388 391 416 392 393 395 448 435 291 297 460 444 370 249 334 227 473 449 461 464 458 367 99 257
322 323 324 326 327 381 379 380 382 384 385 386 387 396 414 401 402 403 404 405 413 415 408 409 410 411 412 417 418 419
420 421 422 423 394 424 425 426 427 428 429 430 431 436 348 437 438 290 293 294 265 295 296 298 439 440 441 300 277 276
442 443 445 446 281 316 317 318 319 320 321 350 468 341 342 343 337 338 339 344 474 475 478 482 484 485 486 462 451 463
465 452 453 454 455 456 457 459 488 ]
2016-01-20 12:05:17,164 DEBUG: com.genesyslab.gax.core.scs.CommunicationService [coreExecutor-1] - [175] Subscribed to Host objects in SCS
[ 137 126 124 125 136 130 121 122 133 138 139 140 142 143 144 141 ]
2016-01-20 12:05:17,391 DEBUG: com.genesyslab.gax.core.scs.CommunicationService [coreExecutor-1] - [175] Subscribed to Solution objects in SCS
[ 121 124 127 128 ]
2016-01-20 12:05:31,034 DEBUG: com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [com.genesyslab.PCT.invoker.default] - [307] message received: ‘EventInfo’ (1) attributes:
attr_obj_live_status [int] = 3
attr_message [str] = “HOST_STATUS_UNAVAILABLE”
attr_cfg_obj_type [int] = 10 [Host]
attr_cfg_obj_id [int] = 133
attr_ref_id [int] = 0
2016-01-20 12:05:31,034 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [com.genesyslab.PCT.invoker.default] - [52] CometD: Number of Subscribers=0
2016-01-20 12:05:31,034 DEBUG: com.genesyslab.gax.core.scs.NotificationService [com.genesyslab.PCT.invoker.default] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:133,“msgtype”:“Host”,“controlstatus”:“Unavailable”}
2016-01-20 12:05:47,409 INFO : com.genesyslab.gax.core.scs.AlarmService [coreExecutor-1] - [59] Registered to ActiveAlarms
2016-01-20 12:05:47,420 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
2016-01-20 12:05:47,420 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:121,“msgtype”:“Host”,“controlstatus”:“Running”}
2016-01-20 12:05:47,421 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:122,“msgtype”:“Host”,“controlstatus”:“Running”}
2016-01-20 12:05:47,421 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
{“controlobjectid”:126,“msgtype”:“Host”,“controlstatus”:“Running”}
{“controlobjectid”:124,“msgtype”:“Host”,“controlstatus”:“Unknown”}
{“controlobjectid”:125,“msgtype”:“Host”,“controlstatus”:“Running”}
2016-01-20 12:05:47,422 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:130,“msgtype”:“Host”,“controlstatus”:“Running”}
2016-01-20 12:05:47,422 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
{“controlobjectid”:137,“msgtype”:“Host”,“controlstatus”:“Unknown”}
{“controlobjectid”:136,“msgtype”:“Host”,“controlstatus”:“Running”}
{“controlobjectid”:138,“msgtype”:“Host”,“controlstatus”:“Running”}
2016-01-20 12:05:47,423 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
2016-01-20 12:05:47,423 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:139,“msgtype”:“Host”,“controlstatus”:“Running”}
{“controlobjectid”:141,“msgtype”:“Host”,“controlstatus”:“Unknown”}
{“controlobjectid”:142,“msgtype”:“Host”,“controlstatus”:“Running”}
{“controlobjectid”:140,“msgtype”:“Host”,“controlstatus”:“Running”}
2016-01-20 12:05:47,424 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
2016-01-20 12:05:47,424 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:144,“msgtype”:“Host”,“controlstatus”:“Running”}
{“controlobjectid”:143,“msgtype”:“Host”,“controlstatus”:“Running”}
2016-01-20 12:05:47,450 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
2016-01-20 12:05:47,450 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:290,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
{“controlobjectid”:326,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
2016-01-20 12:05:47,451 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:327,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
2016-01-20 12:05:47,451 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
{“controlobjectid”:436,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
{“controlobjectid”:293,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
{“controlobjectid”:437,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
2016-01-20 12:05:47,452 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:401,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Backup”}
2016-01-20 12:05:47,452 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
{“controlobjectid”:257,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
{“controlobjectid”:474,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Backup”}
2016-01-20 12:05:47,453 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:294,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
2016-01-20 12:05:47,453 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
{“controlobjectid”:438,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
{“controlobjectid”:402,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
{“controlobjectid”:475,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
2016-01-20 12:05:47,454 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:439,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
2016-01-20 12:05:47,454 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
{“controlobjectid”:295,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
{“controlobjectid”:367,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
{“controlobjectid”:403,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Backup”}
2016-01-20 12:05:47,455 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
2016-01-20 12:05:47,455 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:440,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
{“controlobjectid”:404,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Backup”}
{“controlobjectid”:296,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
2016-01-20 12:05:47,456 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:441,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
2016-01-20 12:05:47,456 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
{“controlobjectid”:405,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
{“controlobjectid”:478,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
{“controlobjectid”:442,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
2016-01-20 12:05:47,457 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
2016-01-20 12:05:47,457 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:298,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
{“controlobjectid”:443,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
{“controlobjectid”:300,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
2016-01-20 12:05:47,458 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:408,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
2016-01-20 12:05:47,458 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
{“controlobjectid”:445,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
{“controlobjectid”:409,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Backup”}
{“controlobjectid”:337,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
2016-01-20 12:05:47,459 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
2016-01-20 12:05:47,459 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:265,“msgtype”:“Application”,“controlstatus”:“Unknown”,“executionmode”:“Exiting”}
{“controlobjectid”:482,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
{“controlobjectid”:338,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
2016-01-20 12:05:47,460 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:446,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
2016-01-20 12:05:47,460 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
{“controlobjectid”:410,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
{“controlobjectid”:339,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
{“controlobjectid”:411,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Backup”}
2016-01-20 12:05:47,461 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
2016-01-20 12:05:47,461 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:484,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
{“controlobjectid”:412,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
{“controlobjectid”:485,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
2016-01-20 12:05:47,462 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:413,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
2016-01-20 12:05:47,462 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
{“controlobjectid”:341,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
{“controlobjectid”:486,“msgtype”:“Application”,“controlstatus”:“Unknown”,“executionmode”:“Exiting”}
{“controlobjectid”:342,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
2016-01-20 12:05:47,463 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
2016-01-20 12:05:47,463 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:414,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Backup”}
{“controlobjectid”:451,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
{“controlobjectid”:343,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
2016-01-20 12:05:47,464 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:379,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
2016-01-20 12:05:47,464 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
{“controlobjectid”:415,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
{“controlobjectid”:488,“msgtype”:“Application”,“controlstatus”:“Unknown”,“executionmode”:“Exiting”}
{“controlobjectid”:452,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
2016-01-20 12:05:47,465 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
2016-01-20 12:05:47,465 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:344,“msgtype”:“Application”,“controlstatus”:“Unknown”,“executionmode”:“Exiting”}
{“controlobjectid”:380,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
{“controlobjectid”:453,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
2016-01-20 12:05:47,466 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:381,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
2016-01-20 12:05:47,466 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
{“controlobjectid”:417,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
{“controlobjectid”:454,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
{“controlobjectid”:382,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
2016-01-20 12:05:47,467 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
2016-01-20 12:05:47,467 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:418,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
{“controlobjectid”:455,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
{“controlobjectid”:419,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
2016-01-20 12:05:47,468 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:456,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
2016-01-20 12:05:47,468 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
{“controlobjectid”:276,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
{“controlobjectid”:384,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
{“controlobjectid”:420,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
2016-01-20 12:05:47,469 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
2016-01-20 12:05:47,469 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:348,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Backup”}
{“controlobjectid”:457,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
{“controlobjectid”:277,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
{“controlobjectid”:385,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
2016-01-20 12:05:47,470 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
2016-01-20 12:05:47,470 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:421,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
{“controlobjectid”:422,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
2016-01-20 12:05:47,471 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:350,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
2016-01-20 12:05:47,471 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
{“controlobjectid”:386,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
{“controlobjectid”:459,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
{“controlobjectid”:387,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
2016-01-20 12:05:47,472 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:423,“msgtype”:“Application”,“controlstatus”:“Initializing”,“executionmode”:“Primary”}
2016-01-20 12:05:47,472 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
{“controlobjectid”:99,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
{“controlobjectid”:316,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
{“controlobjectid”:424,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
2016-01-20 12:05:47,473 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
2016-01-20 12:05:47,473 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:317,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
{“controlobjectid”:281,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
{“controlobjectid”:425,“msgtype”:“Application”,“controlstatus”:“Stopped”,“executionmode”:“Exiting”}
2016-01-20 12:05:47,474 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
2016-01-20 12:05:47,474 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:462,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
2016-01-20 12:05:47,475 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
2016-01-20 12:05:47,475 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:426,“msgtype”:“Application”,“controlstatus”:“Running”,“executionmode”:“Primary”}
{"contro
Hello Cavagnaro,
Not much luck after reinstalling, As per below logs. Is there some trick i am missing or some workaround. I tried cleaning Java cache and installing GAX, then also same error.
Rajnish
As said, DB is your problem. Please fix those errors.
Hello Cavagnaro,
After modifying DB service name details in GAX_DAP. The ora 12514 error is gone but now i am facing different error saying Genesys_silent_ini.xml is missing.
1.ERROR: com.genesyslab.gax.asd.main.ASDPlugin [Thread-19] - [168] File not exist: ./plugin.data/asd/installation/genesys_silent_ini.xml
Please find below the log snippet:-
2016-01-21 00:20:36,920 DEBUG: com.genesyslab.gax.core.scs.SCSConnector [coreExecutor-1] - [88] SCS connector initialization activated
2016-01-21 00:20:37,435 DEBUG: com.genesyslab.gax.core.scs.CommunicationService [coreExecutor-1] - [175] Subscribed to AlarmCondition objects in SCS
2016-01-21 00:20:38,200 INFO : com.genesyslab.gax.core.util.CoreDatabaseInspectorImpl [Thread-15] - [89] ---------- core Database Schema Version ----------
2016-01-21 00:20:38,200 INFO : com.genesyslab.gax.core.util.CoreDatabaseInspectorImpl [Thread-15] - [90] 8.1.301.01
2016-01-21 00:20:38,200 INFO : com.genesyslab.gax.core.util.CoreDatabaseInspectorImpl [Thread-15] - [91] -------------------------------------------------
2016-01-21 00:20:38,200 INFO : com.genesyslab.gax.core.util.CoreDatabaseInspectorImpl [Thread-15] - [41] Db Schema Version for plugin gax-core 8.1.301.01 is matching.
2016-01-21 00:20:38,200 INFO : com.genesyslab.gax.core.util.CoreDatabaseInspectorImpl [Thread-15] - [43] ------------------------------------------------------------------------
2016-01-21 00:20:38,200 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-19] - [89] ---------- asd Database Schema Version ----------
2016-01-21 00:20:38,200 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-19] - [90] 8.5.000.01
2016-01-21 00:20:38,200 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-19] - [91] -------------------------------------------------
2016-01-21 00:20:38,200 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-19] - [41] Db Schema Version for plugin gax-asd 8.5.000.01 is matching.
2016-01-21 00:20:38,200 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-19] - [43] ------------------------------------------------------------------------
2016-01-21 00:20:38,215 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-18] - [89] ---------- opm-arm Database Schema Version ----------
2016-01-21 00:20:38,215 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-18] - [90] 8.1.301.01
2016-01-21 00:20:38,215 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-18] - [91] -------------------------------------------------
2016-01-21 00:20:38,215 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-18] - [41] Db Schema Version for plugin gax-opm-arm 8.1.301.01 is matching.
2016-01-21 00:20:38,215 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-18] - [43] ------------------------------------------------------------------------
2016-01-21 00:20:45,610 INFO : com.genesyslab.gax.asd.main.ASDPlugin [Thread-19] - [83] SPD setup: loaded default scripts
2016-01-21 00:20:45,610 ERROR: com.genesyslab.gax.asd.main.ASDPlugin [Thread-19] - [168] File not exist: ./plugin.data/asd/installation/genesys_silent_ini.xml
2016-01-21 00:20:45,610 ERROR: com.genesyslab.gax.asd.main.ASDPlugin [Thread-19] - [171] Use D:\GCTI\GAX_New_8.5.019/plugin.data/asd/installation/genesys_silent_ini.xml
2016-01-21 00:20:46,826 DEBUG: com.genesyslab.gax.asd.main.ASDPlugin [Thread-19] - [192] Importing gax privileges.
2016-01-21 00:20:46,982 INFO : com.genesyslab.gax.asd.service.roles.RoleImportServiceImpl [Thread-19] - [159] Privilege imported: CfgGenesysAdministratorServer/AUDITING_VIEW_HISTORY into group General
2016-01-21 00:20:46,998 INFO : com.genesyslab.gax.asd.service.roles.RoleImportServiceImpl [Thread-19] - [159] Privilege imported: CfgGenesysAdministratorServer/READ_PLUGINS into group General
2016-01-21 00:20:47,014 INFO : com.genesyslab.gax.asd.service.roles.RoleImportServiceImpl [Thread-19] - [159] Privilege imported: CfgGenesysAdministratorServer/WRITE_PLUGINS into group General
Rajnish
It is clearly mentioned in logs that you have a ORA error wich is actually a database issue.
Can you ping TNS from GAX machine ? also try to telnet ORA port !!
As Rajnish have mentioned, the ORA error is gone.
From my point of view, the log seems to be now fairly clear. I do not think so that the error message about genesys_silent.ini missing is important and blocker. Or still is the GAX unaccessible?
Yeah, that is normal as you didn’t create a silence installer, right?
What happens now?
Still I am facing same issue “http error 404 Problem accessing GAX reason not found powered by jetty”. Clue less why i am still receiving this error.
Rajnish
Check the configuration and logs - nothing more.
Now post GAX logs and http ones
Http Logs:-
0:0:0:0:0:0:0:1 - - [21/Jan/2016:05:21:29 +0000] “GET /gax/ HTTP/1.1” 200 0
0:0:0:0:0:0:0:1 - - [21/Jan/2016:05:21:29 +0000] “GET /favicon.ico HTTP/1.1” 200 0
0:0:0:0:0:0:0:1 - - [21/Jan/2016:05:21:43 +0000] “GET /gax/ HTTP/1.1” 200 0
0:0:0:0:0:0:0:1 - - [21/Jan/2016:05:21:46 +0000] “GET /gax/ HTTP/1.1” 200 0
0:0:0:0:0:0:0:1 - - [21/Jan/2016:06:08:12 +0000] “GET /gax/ HTTP/1.1” 200 0
0:0:0:0:0:0:0:1 - - [21/Jan/2016:06:08:12 +0000] “GET /favicon.ico HTTP/1.1” 200 0
10.96.96.47 - - [21/Jan/2016:12:54:34 +0000] “GET /gax HTTP/1.1” 200 0
10.96.96.47 - - [21/Jan/2016:12:54:34 +0000] “GET /favicon.ico HTTP/1.1” 200 0
10.96.96.47 - - [21/Jan/2016:13:05:39 +0000] “GET /gax HTTP/1.1” 200 0
0:0:0:0:0:0:0:1 - - [21/Jan/2016:14:18:42 +0000] “GET /gax/ HTTP/1.1” 200 0
0:0:0:0:0:0:0:1 - - [21/Jan/2016:14:18:42 +0000] “GET /favicon.ico HTTP/1.1” 200 0
0:0:0:0:0:0:0:1 - - [21/Jan/2016:14:18:45 +0000] “GET / HTTP/1.1” 200 0
0:0:0:0:0:0:0:1 - - [21/Jan/2016:14:18:54 +0000] “GET /gax/ HTTP/1.1” 200 0
0:0:0:0:0:0:0:1 - - [21/Jan/2016:14:18:59 +0000] “GET / HTTP/1.1” 200 0
10.9.116.60 - - [21/Jan/2016:14:21:31 +0000] “GET / HTTP/1.1” 200 0
10.9.116.60 - - [21/Jan/2016:14:21:31 +0000] “GET /favicon.ico HTTP/1.1” 200 0
0:0:0:0:0:0:0:1 - - [21/Jan/2016:14:25:31 +0000] “GET /gax/ HTTP/1.1” 200 0
0:0:0:0:0:0:0:1 - - [21/Jan/2016:14:25:31 +0000] “GET /favicon.ico HTTP/1.1” 200 0
10.96.96.47 - - [21/Jan/2016:14:25:51 +0000] “GET /gax HTTP/1.1” 200 0
0:0:0:0:0:0:0:1 - - [21/Jan/2016:14:29:48 +0000] “GET /gax/ HTTP/1.1” 200 0
0:0:0:0:0:0:0:1 - - [21/Jan/2016:14:29:48 +0000] “GET /favicon.ico HTTP/1.1” 200 0
0:0:0:0:0:0:0:1 - - [21/Jan/2016:14:29:58 +0000] “GET /gax HTTP/1.1” 200 0
0:0:0:0:0:0:0:1 - - [21/Jan/2016:14:30:07 +0000] “GET /gax.war HTTP/1.1” 200 0
10.9.116.60 - - [21/Jan/2016:14:31:47 +0000] “GET /gax HTTP/1.1” 200 0
10.9.116.60 - - [21/Jan/2016:14:31:47 +0000] “GET /favicon.ico HTTP/1.1” 200 0
GAX Logs:-
Version: 8.5.000.91
2016-01-21 09:24:39,131 WARN : com.genesyslab.gax.core.audit.AuditDatabaseBeanManager [main] - [49] Auditing data source is not configured, auditing is disabled!
2016-01-21 09:24:39,568 INFO : com.genesyslab.gax.core.configuration.messageserver.MessageServerAdapter [main] - [180] ------------------------------------------------------------
2016-01-21 09:24:39,568 INFO : com.genesyslab.gax.core.configuration.messageserver.MessageServerAdapter [main] - [181] GAX - MS configuration.
2016-01-21 09:24:39,662 ERROR: com.genesyslab.gax.core.configuration.messageserver.MessageServerAdapter [main] - [187] No MS server found
2016-01-21 09:24:39,677 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [180] ------------------------------------------------------------
2016-01-21 09:24:39,677 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [181] GAX - LCA configuration.
2016-01-21 09:24:39,693 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [202] Timeout in seconds between attempts = 60
2016-01-21 09:24:39,693 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [207] Timeout for LCA = 1000
2016-01-21 09:24:39,693 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [219] Maximum number of connection attempts = 1
2016-01-21 09:24:39,693 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [222] Maximum number of configured switchovers trials = unlimited
2016-01-21 09:24:39,693 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [236] Starting Warmstandby Service
2016-01-21 09:24:39,693 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [238] Warmstandby Service started.
2016-01-21 09:24:39,740 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [180] ------------------------------------------------------------
2016-01-21 09:24:39,740 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [181] GAX - SCS configuration.
2016-01-21 09:24:39,740 DEBUG: com.genesyslab.gax.core.configuration.warmstandby.utils.GaxWarmStandbyListener [com.genesyslab.PCT.invoker.warmstandby] - [36] WarmStandby changed state to Idle.
State:Closed
2016-01-21 09:24:39,802 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [202] Timeout in seconds between attempts = 60
2016-01-21 09:24:39,802 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [219] Maximum number of connection attempts = 1
2016-01-21 09:24:39,802 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [222] Maximum number of configured switchovers trials = unlimited
2016-01-21 09:24:39,802 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [236] Starting Warmstandby Service
2016-01-21 09:24:39,802 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [238] Warmstandby Service started.
2016-01-21 09:24:39,818 DEBUG: com.genesyslab.gax.core.configuration.warmstandby.utils.GaxWarmStandbyListener [com.genesyslab.PCT.invoker.warmstandby] - [36] WarmStandby changed state to Idle.
State:Closed
2016-01-21 09:24:39,818 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [155] Opening connection to SCS Server …
2016-01-21 09:24:39,818 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [155] Opening connection to LCA Server …
2016-01-21 09:24:39,896 WARN : com.genesyslab.gax.core.system.SystemConfigurationImpl [main] - [145]
ga/ga_host: ‘’
ga/ga_port: ‘80’
log/standard: ‘’
log/trace: ‘’
log/verbose: ‘all’
Remaining GAX logs
2016-01-21 09:24:39,958 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [180] ------------------------------------------------------------
2016-01-21 09:24:39,958 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [181] GAX - SCS configuration.
2016-01-21 09:24:40,083 DEBUG: com.genesyslab.gax.core.scs.SCSConnector [coreExecutor-1] - [80] SCS and CS connection monitoring activated.
2016-01-21 09:24:40,176 DEBUG: com.genesyslab.gax.core.configuration.warmstandby.utils.GaxWarmStandbyListener [com.genesyslab.PCT.invoker.warmstandby] - [51] WarmStandby switched channel to tcp://SCS@10.9.111.81:3600.
2016-01-21 09:24:40,176 DEBUG: com.genesyslab.gax.core.configuration.warmstandby.utils.GaxWarmStandbyListener [com.genesyslab.PCT.invoker.warmstandby] - [36] WarmStandby changed state to Waiting.
State:Closed
2016-01-21 09:24:40,254 INFO : com.genesyslab.gax.core.configuration.lca.LcaChannelListener [Thread-12] - [23] Event:Channel tcp://LCA@localhost:4999 is opened.
2016-01-21 09:24:40,254 INFO : com.genesyslab.gax.core.configuration.lca.LcaChannelListener [Thread-12] - [28] Event:updateStatus app name: GAX_New_8.5.103
2016-01-21 09:24:40,254 INFO : com.genesyslab.gax.core.configuration.lca.LcaChannelListener [Thread-12] - [29] Event:updateStatus status: Running
2016-01-21 09:24:40,270 INFO : com.genesyslab.gax.core.configuration.scs.SCSConnectorChannelListener [Thread-11] - [30] Event:Channel tcp://SCS@10.9.111.81:3600 is closed.
2016-01-21 09:24:40,348 DEBUG: com.genesyslab.gax.core.configuration.warmstandby.utils.GaxWarmStandbyListener [com.genesyslab.PCT.invoker.warmstandby] - [36] WarmStandby changed state to Reconnecting.
State:Closed
2016-01-21 09:24:41,144 DEBUG: com.genesyslab.gax.core.configuration.warmstandby.utils.GaxWarmStandbyListener [com.genesyslab.PCT.invoker.warmstandby] - [36] WarmStandby changed state to Idle.
State:Opened
2016-01-21 09:24:41,159 INFO : com.genesyslab.gax.core.configuration.scs.SCSConnectorChannelListener [Thread-19] - [22] Event:Channel tcp://SCS@10.9.111.81:3600 is opened.
2016-01-21 09:24:41,190 DEBUG: com.genesyslab.gax.core.web.notification.CometEventService [Thread-19] - [82] Channel created: /core/scs
2016-01-21 09:24:41,190 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [Thread-19] - [52] CometD: Number of Subscribers=0
2016-01-21 09:24:41,190 DEBUG: com.genesyslab.gax.core.scs.NotificationService [Thread-19] - [34] Publishing message into channel /core/scs:
{“state”:“Opened”,“msgtype”:“Connection”}
2016-01-21 09:24:41,190 DEBUG: com.genesyslab.gax.core.scs.SCSConnector [coreExecutor-1] - [88] SCS connector initialization activated
2016-01-21 09:24:41,237 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-17] - [89] ---------- asd Database Schema Version ----------
2016-01-21 09:24:41,237 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-17] - [90] 8.5.000.01
2016-01-21 09:24:41,237 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-17] - [91] -------------------------------------------------
2016-01-21 09:24:41,237 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-17] - [41] Db Schema Version for plugin gax-asd 8.5.000.01 is matching.
2016-01-21 09:24:41,237 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-17] - [43] ------------------------------------------------------------------------
2016-01-21 09:24:41,300 INFO : com.genesyslab.gax.core.util.CoreDatabaseInspectorImpl [Thread-18] - [89] ---------- core Database Schema Version ----------
2016-01-21 09:24:41,300 INFO : com.genesyslab.gax.core.util.CoreDatabaseInspectorImpl [Thread-18] - [90] 8.1.301.01
2016-01-21 09:24:41,300 INFO : com.genesyslab.gax.core.util.CoreDatabaseInspectorImpl [Thread-18] - [91] -------------------------------------------------
2016-01-21 09:24:41,300 INFO : com.genesyslab.gax.core.util.CoreDatabaseInspectorImpl [Thread-18] - [41] Db Schema Version for plugin gax-core 8.1.301.01 is matching.
2016-01-21 09:24:41,300 INFO : com.genesyslab.gax.core.util.CoreDatabaseInspectorImpl [Thread-18] - [43] ------------------------------------------------------------------------
2016-01-21 09:24:41,300 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-14] - [89] ---------- opm-arm Database Schema Version ----------
2016-01-21 09:24:41,300 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-14] - [90] 8.1.301.01
2016-01-21 09:24:41,300 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-14] - [91] -------------------------------------------------
2016-01-21 09:24:41,300 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-14] - [41] Db Schema Version for plugin gax-opm-arm 8.1.301.01 is matching.
2016-01-21 09:24:41,300 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-14] - [43] ------------------------------------------------------------------------
2016-01-21 09:24:42,095 DEBUG: com.genesyslab.gax.core.scs.CommunicationService [coreExecutor-1] - [175] Subscribed to AlarmCondition objects in SCS
2016-01-21 09:24:44,778 INFO : com.genesyslab.gax.asd.main.ASDPlugin [Thread-17] - [83] SPD setup: loaded default scripts
2016-01-21 09:24:45,387 DEBUG: com.genesyslab.gax.asd.main.ASDPlugin [Thread-17] - [195] Skipping GAX privileges load.
2016-01-21 09:24:45,387 DEBUG: com.genesyslab.gax.asd.main.ASDPlugin [Thread-17] - [197] Importing gax default roles.
2016-01-21 09:24:45,465 DEBUG: com.genesyslab.gax.asd.main.ASDPlugin [Thread-17] - [184] Reseting deployments state.
2016-01-21 09:24:45,605 INFO : com.genesyslab.gax.asd.main.ASDPlugin [Thread-17] - [102] ASD initialized
2016-01-21 09:24:46,884 DEBUG: com.genesyslab.gax.core.scs.CommunicationService [coreExecutor-1] - [175] Subscribed to Application objects in SCS
2016-01-21 09:24:46,947 DEBUG: com.genesyslab.gax.core.scs.CommunicationService [coreExecutor-1] - [175] Subscribed to Host objects in SCS
2016-01-21 09:24:46,978 DEBUG: com.genesyslab.gax.core.scs.CommunicationService [coreExecutor-1] - [175] Subscribed to Solution objects in SCS
[ 121 124 127 128 ]
2016-01-21 09:25:02,126 DEBUG: com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [com.genesyslab.PCT.invoker.default] - [307] message received: ‘EventInfo’ (1) attributes:
2016-01-21 09:25:02,126 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [com.genesyslab.PCT.invoker.default] - [52] CometD: Number of Subscribers=0
2016-01-21 09:25:02,126 DEBUG: com.genesyslab.gax.core.scs.NotificationService [com.genesyslab.PCT.invoker.default] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:133,“controlstatus”:“Unavailable”,“msgtype”:“Host”}
2016-01-21 09:25:16,992 INFO : com.genesyslab.gax.core.scs.AlarmService [coreExecutor-1] - [59] Registered to ActiveAlarms
2016-01-21 09:25:17,008 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
2016-01-21 09:25:17,008 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:121,“controlstatus”:“Running”,“msgtype”:“Host”}
{“controlobjectid”:122,“controlstatus”:“Running”,“msgtype”:“Host”}
{“controlobjectid”:126,“controlstatus”:“Running”,“msgtype”:“Host”}
{“controlobjectid”:124,“controlstatus”:“Unknown”,“msgtype”:“Host”}
{“controlobjectid”:125,“controlstatus”:“Running”,“msgtype”:“Host”}
{“controlobjectid”:130,“controlstatus”:“Running”,“msgtype”:“Host”}
{“controlobjectid”:137,“controlstatus”:“Unknown”,“msgtype”:“Host”}
{“controlobjectid”:136,“controlstatus”:“Running”,“msgtype”:“Host”}
{“controlobjectid”:138,“controlstatus”:“Running”,“msgtype”:“Host”}
{“controlobjectid”:139,“controlstatus”:“Running”,“msgtype”:“Host”}
2016-01-21 09:25:17,024 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
2016-01-21 09:25:17,024 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:141,“controlstatus”:“Unknown”,“msgtype”:“Host”}
{“controlobjectid”:142,“controlstatus”:“Running”,“msgtype”:“Host”}
{“controlobjectid”:140,“controlstatus”:“Running”,“msgtype”:“Host”}
{“controlobjectid”:144,“controlstatus”:“Running”,“msgtype”:“Host”}
{“controlobjectid”:143,“controlstatus”:“Running”,“msgtype”:“Host”}
2016-01-21 09:25:17,055 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
2016-01-21 09:25:17,055 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:290,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:326,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:327,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:436,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:293,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:437,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:401,“controlstatus”:“Running”,“executionmode”:“Backup”,“msgtype”:“Application”}
{“controlobjectid”:257,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:474,“controlstatus”:“Running”,“executionmode”:“Backup”,“msgtype”:“Application”}
{“controlobjectid”:294,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:438,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:402,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:475,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:439,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:295,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:367,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:403,“controlstatus”:“Running”,“executionmode”:“Backup”,“msgtype”:“Application”}
{“controlobjectid”:440,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:404,“controlstatus”:“Running”,“executionmode”:“Backup”,“msgtype”:“Application”}
{“controlobjectid”:296,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:441,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:405,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:478,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:442,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:298,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:443,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
2016-01-21 09:25:17,070 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:300,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
2016-01-21 09:25:17,070 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
{“controlobjectid”:408,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:445,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:409,“controlstatus”:“Running”,“executionmode”:“Backup”,“msgtype”:“Application”}
{“controlobjectid”:337,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:265,“controlstatus”:“Unknown”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:482,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:338,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:446,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:410,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:339,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:411,“controlstatus”:“Running”,“executionmode”:“Backup”,“msgtype”:“Application”}
{“controlobjectid”:484,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:412,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:485,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:413,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:341,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:486,“controlstatus”:“Unknown”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:342,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:414,“controlstatus”:“Running”,“executionmode”:“Backup”,“msgtype”:“Application”}
{“controlobjectid”:451,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:343,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:379,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:415,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:488,“controlstatus”:“Unknown”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:452,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:344,“controlstatus”:“Unknown”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:380,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:453,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:381,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:417,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:454,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:382,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:418,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:455,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:419,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:456,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:276,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:384,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:420,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:348,“controlstatus”:“Running”,“executionmode”:“Backup”,“msgtype”:“Application”}
{“controlobjectid”:457,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:277,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:385,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:421,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:422,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:350,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:386,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:459,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:387,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
2016-01-21 09:25:17,086 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
2016-01-21 09:25:17,086 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:423,“controlstatus”:“Initializing”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:99,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:316,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:424,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:317,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:281,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:425,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:462,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:426,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:318,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:463,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:427,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:319,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:320,“controlstatus”:“Running”,“executionmode”:“Backup”,“msgtype”:“Application”}
{“controlobjectid”:428,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:465,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:321,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:429,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:322,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:394,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:430,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:431,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:323,“controlstatus”:“Running”,“executionmode”:“Primary”,“msgtype”:“Application”}
{“controlobjectid”:468,“controlstatus”:“Unknown”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:324,“controlstatus”:“Stopped”,“executionmode”:“Exiting”,“msgtype”:“Application”}
{“controlobjectid”:396,“controlstatus”:“Running”,“executionmode”:“Backup”,“msgtype”:“Application”}
2016-01-21 09:25:17,117 TRACE: com.genesyslab.gax.core.web.notification.CometEventService [coreExecutor-1] - [52] CometD: Number of Subscribers=0
2016-01-21 09:25:17,117 DEBUG: com.genesyslab.gax.core.scs.NotificationService [coreExecutor-1] - [34] Publishing message into channel /core/scs:
{“controlobjectid”:124,“controlstatus”:“Stopped”,“msgtype”:“Solution”}
{“controlobjectid”:121,“controlstatus”:“Running”,“msgtype”:“Solution”}
I do not see that you have configured the non-default HTTP port. Could you provide us how did you configure it? If the posted logs is entire, in this case the Jetty did not startup properly and the port was not opened for listening.
I have provided port and root url using gax.properties under D:\GCTI\GAX\conf. Below is the content of file:
backup_port=2020
port=2020
backup_host=frdwgeap02d.dev.invitrogen.net
host=frdwgeap01d.dev.invitrogen.net
app=GAX_New_8.5.103
http_port=9999
root_url=http://frdwgysapp03d.dev.invitrogen.net:9999/gax
Below is the setup file i am using/passing to gax while setup using using command line.
Configuration_Server_Host=frdwgeap01d.dev.invitrogen.net
Configuration_Server_Port=2020
Default_Client_Application_Name=default
Configuration_Server_Username=default
Configuartion_Server_Password=password
Application_Object_Name=GAX_New_8.5.103
Database_Server_Type=Oracle
Database_Host=10.9.104.89
Database_Port=1521
Database_Name=DVI_GNSS.AB.APPLERA.NET
Database_Username=sadmin
Database_Password=password for sadmin
Rajnish
Hello Kubig,
If i have made something wrong in providing http port to application. Request you to guide me where exactly i need to pass the http port info.
Rajnish
