Problem Accessing GAX "HTTP error 404"
I’m facing the same issue, can you help with your solution?
Regards.
At least post your logs please
Old post so probably as different problem.
2016-01-21 09:25:02,126 DEBUG: com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [com.genesyslab.PCT.invoker.default] - [307] message received: ‘EventInfo’ (1) attributes:
attr_obj_live_status [int] = 3
attr_message [str] = “HOST_STATUS_UNAVAILABLE”
attr_ref_id [int] = 0
attr_cfg_obj_id [int] = 133
attr_cfg_obj_type [int] = 10 [Host]
Question, the problem started since you install PULSE in GAX? Did you define GAX ROLE in both GAX and Pulse Collector DAP?
i had the same issue, and it was solved defining the role in both DAPs.
Regards,
