Just noticed that predictive routing capacity metrics diverge from ServiceNow CMDB availability data by roughly 15% during peak London hours. The Data Action pushing skill assignments to Genesys Cloud completes with a 200 OK, yet the routing engine ignores the updated capacity values.
The webhook payload includes valid skill_group_id and capacity fields, matching the schema in the docs. ServiceNow logs confirm the update occurred, but Genesys Cloud Architect shows stale capacity for the digital channel queue.
Is there a known caching delay for predictive routing capacity updates triggered via Data Actions? Or is the force_refresh parameter required in the payload to invalidate the routing engine cache immediately?
Environment: Genesys Cloud EU1, ServiceNow Washington DC release, Data Action version 2.1.
Make sure you map ServiceNow capacity directly to Genesys Cloud skill group capacity limits. The Data Action likely updates the record but does not trigger the routing engine’s real-time capacity check.
In Zendesk, we relied on static tags. Here, verify the Architect flow explicitly reads the updated capacity variable before routing. Check if the Data Action returns the new value correctly.
The Data Action returning 200 OK does not guarantee the routing engine has processed the change, as there is often a propagation delay. Verify if the flow includes a wait step or if the capacity variable is being cached before the route decision, rather than relying on the immediate webhook response.
What’s happening here is that a 200 OK from the Data Action only confirms receipt, not propagation to the routing engine. WFM schedules often suffer from similar latency where the UI shows updated adherence but the backend hasn’t caught up. The routing engine caches skill group capacity for performance, meaning your ServiceNow update sits in a queue until the next sync cycle or cache invalidation event triggers.
To fix this, bypass the standard Data Action delay by using a direct API call to update the skill group capacity immediately before the route decision. This ensures the routing engine sees the fresh values. Also, check if your Genesys Cloud instance has any scheduled maintenance windows overlapping with peak London hours, as background jobs can sometimes pause real-time updates. Adding a small delay or a conditional check for the new capacity value in the flow helps prevent mismatched routing decisions.
