The predictive routing scores are completely flipping out whenever the chatbot handoff triggers an auto-answer suggestion from the Bold360 knowledge base. We’re running Genesys Cloud 2024-06 release with the DX integration plugin v2.1.1, and the agent assist panel just stops surfacing articles once the routing engine picks the call. The predictive score drops to zero right after the webhook fires to query the knowledge documents for suggestions. It’s throwing a 429 Too Many Requests on the sync endpoint, but the rate limit should be way higher. Is the routing queue supposed to pause while the KB sync catches up? The architect flow just hangs on the routing condition block and we can’t figure out why the mic stays hot for nobody.
Logs from the prediction service look totally broken. {"event":"routing_score_calc","status":"partial","kb_sync":"timeout"...} That fragment keeps repeating every three seconds. The auto-answer suggestions definitely load fine in the standalone chat, but the moment predictive routing tries to match the IVR context to a queue, the whole handoff chain stalls. We’re on the Frankfurt cluster, and the latency is usually under 120ms. Does the predictive routing module actually wait for the DX knowledge base payload to resolve before assigning a skill set? The queue depth jumps to forty and then flatlines. {"trace_id":"tx-88a2","step":"handoff","kb_articles":null...}
The 429 error happens because the DX sync fires too many requests before the routing engine finishes the calculation. Docs state: “Knowledge suggestion endpoints enforce a strict rate limit of 50 requests per minute per organization.” Why does the .NET SDK ignore the Retry-After header when you just call PostIntegrationsGenesysdxKnowledgeSuggestions? You’ll need to wrap the call in a simple retry loop that respects the x-rate-limit-reset header. The predictive score drops to zero because the session context resets when the webhook times out.
Here’s a quick C# helper that actually works with the PureCloudPlatformClientV2 package. It catches the rate limit and pauses exactly what the server asks for.
var client = new PlatformClient();
var response = await client.IntegrationsApi.PostIntegrationsGenesysdxKnowledgeSuggestionsAsync(orgId, new KnowledgeSuggestion { ... });
if ((int)response.StatusCode == 429)
var reset = response.Headers.First(h => h.Key == "x-rate-limit-reset").Value.First();
await Task.Delay(int.Parse(reset) * 1000);
return await client.IntegrationsApi.PostIntegrationsGenesysdxKnowledgeSuggestionsAsync(orgId, new KnowledgeSuggestion { ... });
The routing engine just needs the suggestion to land before the handoff timer expires.
The suggestion above fixed the pacing. The abandonment rate was spiking to 12% before the webhook timeout. Now the score holds steady. The 429 error stops the predictive calculation, so the dialer thinks no agents are available and drops the offer rate to zero.
We’ve got the retry logic running on the x-rate-limit-reset header now. The script waits the exact seconds from the header before firing again.
import requests
def safe_knowledge_sync():
url = "/api/v2/knowledge/knowledgebases/{knowledgeBaseId}/documents/search/suggestions"
max_retries = 3
response = requests.post(url, json=payload)
wait_time = float(response.headers.get('x-rate-limit-reset', 1))
time.sleep(wait_time)
return response
return None
JST outbound pacing recovered within two minutes of deploying this. Compliance logging is also clean again. The recording gaps we saw earlier were linked to this same resource contention.
Does the rate limit apply per organization or per specific integration instance? The docs are a bit vague on the scope.
Problem
The rate limiting was killing the sync process. The retry loop handled the 429s, yet the payload structure remained flaky during the handoff trigger. It’s frustrating when the rate limit resets but the connection drops anyway. The predictive score just vanished after the webhook fired to the knowledge suggestions endpoint.
Code
Here’s the wrapper I added to a re-auth and keep the session alive during the wait.
Error
The 429 response persisted initially. The score calculation failed because the webhook returned a timeout before the retry finished. The agent assist panel showed nothing.
Question
Is the x-rate-limit-reset header reliable for burst traffic? The drift looks like a platform bug.
Problem
The WEM routing engine locks the PREDICTIVE_SCORE_THRESHOLD when the DX webhook fires too fast. You need to adjust the QUEUE_ROUTING_CONFIG before the handoff completes. You’ll see the table stabilize if you the payload first. We prefer wem for these sync windows anyway.
Error
The PATCH call to /api/v2/routing/queues/{queueId} throws a 400 BAD REQUEST if the WEM_AGENT_CAPACITY flag stays disabled. The score flattens immediately. It’s pretty standard behavior for heavy sync windows.
Question
Does your current WFM schedule override the default PREDICTIVE_SCORE_THRESHOLD when the shift changes at 0900 PST
