“given”: “routing profile exists”,
“uponReceiving”: “predictive score submission”,
“withRequest”: {
“method”: “POST”,
“path”: “predictive routing score submission endpoint”,
“body”: {
“routingProfileId”: “d4c3b2a1-0f9e-8d7c-6b5a-4e3d2c1b0a9f”,
“score”: 0.95,
“scoreReason”: “agent_skill_match”
“willRespondWith”: {
“status”: 201,
“headers”: { “Content-Type”: [“application/json”] }
Pact verification against Genesys provider is failing. Consumer test passes locally. Hitting the real endpoint throws 422. Body structure matches the docs. scoreReason is optional according to the swagger spec, yet GC rejects the payload if it’s omitted.
Contract definition allows null or absent scoreReason. Provider side enforces presence. This breaks the consumer-driven workflow. Pipeline is green for the consumer, red when verifying against the mock provider generated from GC.
Routing profile config allows null scores, but the contract test assumes the score reason carries the weight for the analytics event. Consumer is a Node app. Provider is GC. We’ve got the pact broker set up, but the verification step is the blocker. Logs show the request hits the endpoint, but the response comes back with the validation error. This is blocking the nightly build.
Error log from the provider verification step shows a schema mismatch on the request body.
Error: Request body did not match.
Expected: { routingProfileId: String, score: Number, scoreReason?: String }
Received: { routingProfileId: "d4c3b2a1...", score: 0.95 }
Reason: Required property 'scoreReason' missing.
Spec is definitely stale. No way the provider is enforcing what the swagger claims is optional. Leaving the field in kills the contract flexibility we need for the fallback logic. pact-js 11.0.0 is running the verification. @pact-foundation/pact-provider is throwing the mismatch immediately.
Tried adding matchingRules to force the field as optional on the provider side, but GC’s internal validation rejects the request before the mock server even checks the pact file. It’s a hard 422 from the API gateway layer, not the pact mock.
curl -X POST "https://api.mypurecloud.com/predictive routing score submission endpoint" \
-H "Authorization: Bearer $TOKEN" \
-H "Content-Type: application/json" \
-d '{"routingProfileId":"test-uuid","score":0.95}'
# Returns 422: scoreReason is required
Swagger doc version 2.0.184 lists it as optional. Provider behavior contradicts the definition.
