Predictive Routing model scores vanish when Agent Assist transcription buffer exceeds 40 seconds
Predictive scores flatline the moment the transcription buffer crosses the 40-second mark. The whole point here is AI ROI and knowledge surfacing based on sentiment. Agent Assist pushes snippets while the router sorts the heavy calls. Instead, the model just bails. Calls bounce to Random after the customer talks for 45 seconds. The senior queue misses the complex interactions. ROI numbers look like garbage.
Architect flow shows the predictive routing action pulling the sentiment score every 10 seconds. Short interactions work fine. Real-time transcription stream gets heavy, and the v2/predictive-routing/models endpoint throws a 502 Bad Gateway on the score update.
 "code": "predictive_service_timeout",
 "message": "Internal server error during model inference",
 "details": "Transcription buffer size exceeds limit for concurrent sentiment analysis"
Workaround attempt: lowered the transcription chunk size in Agent Assist settings. Latency just shifts. Disabled knowledge surfacing rules to isolate the thread. Predictive scores still dropped. Underlying sentiment engine is hitting a resource cap when paired with the predictive model. Mic stays hot on the transcription side and the inference queue backs up.
[Screenshot: Predictive routing health dashboard showing red spikes correlating with high transcription volume]
Pilot program is in trouble. Client expects the AI to handle the load, but routing is doing jack all. Trace logs show the inference job queued but never completing.
2024-05-20T14:32:11Z WARN predictive-routing-worker: Inference queue depth > 500. Dropping batch for skill_id=skill_ai_senior.
Queue depth keeps climbing while the model stops updating.
The transcription buffer limit is a known constraint in the current Agent Assist architecture, so routing based on live text doesn’t hold up after forty seconds.
Bypassing the text feed by pulling the raw audio stream via the recordings endpoint and running a local worker usually keeps the sentiment model stable. Future setups will just route off the audio waveform directly.
Pushing raw audio to a local worker is gonna brick your Max Concurrent Sessions limit and recreate the exact latency spikes. Are you feeding the model off the initial IVR node or letting it sit in a hold queue while the buffer fills? You’ll need to cap the Transcription Buffer Timeout at 25s and map the sentiment output to a Routing Score attribute before the call hits the queue, otherwise the predictive action just drops the call.
