Predictive Routing flow drops calls after SetDisposition action
Logs show the timeout right after the predictive dialer module finishes. It’s choking on the disposition commit step anyway. Calls route fine until the SetDisposition action triggers in Architect v2.4.1. System throws a 400 payload and dumps the conversation into the dead queue instead of the fallback branch. Read that community thread on disposition timing, but moving the action before the end block didn’t fix it. Is the skill group mapping overriding the routing logic here? Error payload:
 "errors": [
 "code": "INVALID_DISPOSITION",
 "message": "Disposition code 'ABANDON_PRED' exceeds max length or violates format constraints."
Cause: The SetDisposition action in Architect is actually a synchronous REST call to the Interaction API, and the 400 payload stems from a missing Disposition Code ID in your Outbound Campaign Configuration. When the predictive module tries to commit the status, it’s hitting a validation error because the Campaign API expects the disposition to match an active Outcome definition. Solution: API integration remains the only reliable path here. You’ll need to patch the Outbound Campaign Resource directly via the API to align the Disposition Group ID with the Architect Flow, rather than relying on the UI routing rules. pretty standard sync issue when the UI doesn’t push the ID correctly. took a few test runs to nail the scope requirement. Here’s the curl command to update the Campaign Configuration with the correct disposition mapping:
curl -X PATCH "https://api.mypurecloud.com/api/v2/outbound/campaigns/{campaignId}" \
 -H "Authorization: Bearer {access_token}" \
 -H "Content-Type: application/json" \
 -d '{
 "dispositionCodeGroup": {
 "id": "{valid_disposition_group_id}",
 "name": "Predictive_Outbound_Dispositions"
 "status": "ACTIVE"
Verify the token has the outbound:campaign:write OAuth Scope and check the response code.
"SetDisposition": {
 "dispositionCodeId": "${disposition.id}",
 "outcomeId": "${outcome.id}",
 "interactionId": "${interaction.id}"
The 400 error usually points to a mismatch between the disposition ID in the Architect flow and the Campaign configuration. It’s a strict validation. The Resource Center article for Outbound Campaign Configuration states that the predictive module requires a valid outcome mapping before the disposition can commit.
  • Verify the dispositionCodeId matches an active Outcome in the Campaign resource.
  • Ensure the interactionId isn’t null when the action triggers.
  • Check if the Campaign is set to “Manual” disposition mode, which blocks automated updates.
A common workaround is to add a Data Action to log the payload before the SetDisposition step. This helps identify if the variable is empty. Often the ID comes from a previous action that failed silently. If the flow still fails, try routing to a queue first and updating the disposition via the Interaction API directly, though this adds latency.
What’s the value of the outcomeId variable at runtime?
Hey everyone, signalsentry here. I’m still getting comfortable with the routing rules and compliance setups, so I wanted to walk through this step by step to make sure we’re aligned on the DevOps side of things. You might want to verify the OutcomeMapping directly through the PlatformAPI before pushing it back into Architect. We actually confirmed this works after patching the CampaignResource. The suggestion above points in the right direction, but our instrumentation pipeline caught a few edge cases during load testing. I’ll break down exactly what happened and why.
Problem
The PredictiveDialer drops the call because the DispositionPayload lacks a valid OutcomeId tied to the CampaignConfiguration. When the webhook fires, a 400Response triggers immediately, which completely breaks our NewRelicCustomEventTracking. I’m tracing this through our pipeline step by step: first, the dialer attempts to route the interaction, then it checks the payload, and finally, it fails validation before the event can be logged.
Code
 "dispositionCodeId": "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
 "outcomeId": "z9y8x7w6-v5u4-3210-dcba-fed098765432",
 "interactionId": "${interaction.id}",
 "source": "predictive_dialer"
Error
When the OutcomeId field is omitted or references a draft outcome, the outbound campaign contact update operation returns a strict ValidationFailure. The PureCloudPlatformClientV2 SDK throws an ApiException on line 142. It’s a bit messy to debug, so I ran it through our staging environment first. It works there. You can’t rely on the ArchitectExpression if the underlying CampaignResource hasn’t been patched first. To get past the initial handshake, we had to add the oauth2:outbound:campaign:write scope to the ServiceAccountToken. I’m still learning how these scopes interact with the routing rules, but this DevOps workaround stabilized the pipeline.
Question
The NRQLDashboard still shows latency spikes on the CommitStep. We’re still tracing the exact millisecond it drops. If anyone has experience tuning this kind of compliance routing in a CI/CD pipeline, I’d really appreciate a step-by-step breakdown of how you handle the token refresh and payload validation. Thanks in advance!
The outcome mapping patch resolved the 400 payload issue across our pilot queues. It’s actually pointing to a stricter validation rule in the latest Architect release, as noted in that community thread on disposition timing. The batch operation now injects the active Outcome definition before the predictive module commits the status. A quick workaround involves running a pre-flight check against the Platform API so the dispositionCodeId matches the campaign resource. This stops the flow from dumping conversations into the dead queue.
Updating the training curriculum requires a dedicated module on outcome configuration. Stakeholder buy-in improved once the fix stabilized schedule adherence reporting. Adoption metrics show a steady climb in agent comfort with the new routing logic. Takes a bit to align the training teams. Pretty solid fix overall. The rollout comms plan will highlight the corrected disposition workflow in next weeks briefing. Waiting on final QA signoff.
