Trying to understand why predictive routing capacity metrics diverge from ServiceNow CMDB availability data by roughly 15% during peak London hours. The Data Action pushing skill assignments to Genesys Cloud triggers successfully, yet agent capacity remains stale in the routing engine. The webhook payload validates correctly against the schema, and the ServiceNow REST API returns 200 OK. Is there a known caching delay in the Genesys Cloud routing service that causes this drift, or should I adjust the Data Action retry logic?
Thanks for any insights.
Have you tried mapping the ServiceNow capacity directly to Genesys Cloud skill group capacity limits instead of relying solely on the Data Action? The suggestion above regarding the webhook payload is valid, but if you are migrating from Zendesk, you might be used to handling timeout issues differently. In Zendesk, ticket assignments are often static until closed, whereas Genesys Cloud uses real-time predictive routing that requires immediate state updates. The Data Action likely updates the record in the CMDB but does not trigger the routing engine’s real-time capacity check. You need to ensure the skill group capacity is explicitly set via the Genesys Cloud API, not just the user status.
This discrepancy usually stems from how agent availability is calculated. Zendesk’s view is often agent-centric, while Genesys Cloud is skill-centric. Try adding a Set Skill Group Capacity block in your Architect flow after the Data Action completes. This forces the routing engine to recalculate the predictive queue metrics immediately. Also, check the webhook retry logic; sometimes the 200 OK is returned before the internal cache refreshes. Setting a small delay or using the Genesys Cloud Events API to listen for capacity changes can help synchronize the data faster.
