Predictive Routing capacity mismatch with WFM published schedules
Dealing with a very strange bug here with predictive routing capacity calculations during our weekly publish cycle. The WFM engine in Genesys Cloud 2024-02 seems to ignore the concurrent session limits defined for our digital messaging agents when pushing the schedule to the routing engine. We are seeing a significant spike in abandoned calls because the predictive dialer thinks we have 40 agents available, but the WFM schedule only shows 25 logged in for that specific shift block.
The API returns a 200 OK on the schedule push, yet the real-time adherence dashboard shows a massive discrepancy. We are running this in the America/Chicago timezone environment. Has anyone seen the predictive routing engine fail to sync with the WFM capacity constraints? We have verified the skill assignments and the shift swap approvals are all valid. The issue persists even after clearing the cache and republishing. This is causing major issues for our workforce planning metrics. Any insights on how to force a hard sync between WFM capacity and predictive routing targets?
TL;DR: The predictive routing capacity mismatch usually stems from a delay in the WFM-to-Routing sync webhook, causing stale agent state data. Verify the Data Action timeout and ensure the available status is explicitly pushed.
The documentation actually says that WFM schedule publishes are asynchronous events that trigger downstream Data Actions. If the predictive dialer is reading from the real-time routing engine before the WFM sync completes, it will rely on the previous shift’s agent count. This explains why the dialer sees 40 agents while the schedule reflects 25.
Check the Data Action flow handling the wfm.schedule.publish event. A common failure point is a silent timeout where the ServiceNow REST API or internal Genesys update fails to propagate the new concurrent_session_limit values. You need to ensure the payload flattening logic correctly maps agent_id to routing_state.
Inspect the webhook payload structure. It should look like this:
 "event": "wfm.schedule.publish",
 "data": {
 "agents": [
 "id": "agent_123",
 "state": "available",
 "concurrent_sessions": 1
If the state field is missing or defaults to offline, the routing engine will not count the agent. Add a retry mechanism in the Data Action for HTTP 5xx errors. Also, verify that the ServiceNow incident creation for sync failures is not blocking the main thread. A 413 or 500 error in the sync webhook will halt the update, leaving the predictive dialer with outdated capacity metrics.
Force a manual re-publish of the WFM schedule and monitor the Data Action execution logs. Look for status: success on the routing update step. If the logs show a timeout, increase the socket timeout to 120000 ms. This ensures the full agent roster syncs before the next predictive dialing cycle begins.
This happens because the asynchronous nature of the wfm to routing sync, which i’ve seen frequently with apac byoc trunks. the predictive engine reads state before the data action completes. check the event logs for the specific publish transaction id. if you see a 409 conflict or timeout, the sync failed silently. we usually add a retry loop in our custom data action to ensure the agent state updates. also, verify that the ‘available’ status is explicitly pushed in the webhook payload. sometimes the default sync only updates shift start times, not real-time availability. try adding a small delay in your flow before the predictive campaign starts, or use a custom attribute to flag agents as ‘ready’ only after the sync confirms. this helps align the dialer’s view with the actual logged-in count. it’s a pain but necessary for accurate capacity planning.
