Predictive routing capacity mismatch with WEM schedule snapshot
The predictive routing queue is suddenly pulling agents from the wrong management unit during peak inbound hours. Adherence drops to 78 percent while the system claims occupancy is at 92. It’s throwing a WR-503 sync mismatch in the WEM dashboard.
Environment details:
  • Genesys Cloud CX version 2024.02
  • 5000-seat BPO split across three management units
  • Predictive routing enabled with standard capacity thresholds
  • Shift trades approved via WEM calendar
The routing algorithm seems to ignore the scheduled shrinkage factors we configured last quarter. People often assume predictive routing automatically adjusts to shift trades, but the system actually relies on the published schedule snapshot at midnight. If a trade processes after that window, the capacity calculation stays frozen. There’s also an edge case with part-time agents working split shifts. Their availability windows don’t always align with the predictive engine’s rolling forecast, which causes the queue to over-pull. The Architect flow routing step is set to respect management unit boundaries, yet the WEM feed isn’t updating the capacity pool.
We’ve tried clearing the WEM cache and re-publishing the schedule. The dashboard still shows the discrepancy. Capacity planning metrics are drifting. Doing jack all to fix the shrinkage calculation.
Hi.
WR-503 Sync Mismatch arises when Shift Trades are approved in Calendar UI while Routing Engine Capacity Cache remains stale. Predictive Routing consumes stale snapshots if WEM Schedule lacks explicit re-sync post Bulk Modifications. Verify Routing Engine state against Dashboard View via Admin UI.
let client = reqwest::Client::new();
let res = client.get("https://api.mypurecloud.com/api/v2/workforcemanagement/agents/me/managementunit")
 .header("Authorization", format!("Bearer {}", token))
 .header("Accept", "application/json")
 .send()
 .await?;
let snapshot: serde_json::Value = res.json().await?;
println!("{:#?}", snapshot["availableCapacity"]);
Payload reveals WorkPlan assignments and AvailableCapacity. Discrepancy with 92 percent occupancy indicates Queue Threshold Configuration references incorrect Management Unit ID. Update Queue Settings to trigger Cache Invalidation. Ensure client possesses WFM:Schedule:View and Routing:Queue:Write scopes. PureCloudPlatformClientV2 method platformClient.wfm_schedule_api().get_schedule_agents() auto-handles pagination; raw HTTP suffices for checks.
curl -X PUT "https://api.mypurecloud.com/api/v2/routing/queues/{queueId}" \
 -H "Authorization: Bearer <ACCESS_TOKEN>" \
 -H "Content-Type: application/json" \
 -d '{"managementUnitIds": ["{correctMUId}"]}'
Inspect ManagementUnitIds array. Routing Service inherits legacy Management Unit Mappings upon Queue Template cloning. Diff Snapshot JSON to isolate mismatch prior to threshold adjustment.
