Does anyone know how to properly handle rate limiting for Predictive Outbound campaigns when simulating high concurrency?
Background
I am running load tests for a new Predictive Outbound campaign setup in the ap-southeast-1 region. The goal is to validate API throughput and system stability under stress. I am using JMeter to simulate a burst of call dispositions and campaign status updates. The script targets the /api/v2/outbound/campaigns/{id}/start endpoint followed by rapid succession calls to update the campaign configuration to handle disposition codes. My JMeter thread group is configured with 200 concurrent users, ramp-up period of 10 seconds, and a loop count of 5. This is meant to mimic a high-volume BPO environment during peak hours.
Issue
Almost immediately after the ramp-up phase, the responses start failing. Instead of the expected 200 OK or 202 Accepted, I am getting a flood of 429 Too Many Requests errors. The response headers include Retry-After: 1, but even with that delay, the error rate stays above 80% when concurrency exceeds 50 threads. The error message body just says “Rate limit exceeded”. This is happening specifically for the predictive dialer endpoints, while other API calls like user management seem fine.
Troubleshooting
I have checked the API documentation and confirmed the rate limits for outbound operations. I tried adding a constant throughput timer in JMeter to limit requests per second, but the errors persist. I also verified that the campaign is active and has enough contacts. The issue seems to be tied to the concurrent nature of the predictive dialer logic rather than a simple endpoint limit. Is there a specific header or parameter I need to include to handle predictive outbound load better? Or is there a known limitation for ap-southeast-1 that I am missing? Any advice on tuning JMeter for this specific use case would be appreciated.
This is caused by thread group pacing that ignores Genesys Cloud’s API rate limits, unlike Zendesk’s bulk import throttling. Adjust Ramp-Up Period and Concurrent Users in JMeter to match the natural flow of Zendesk ticket updates. This prevents the 429 errors by smoothing out the burst of disposition calls.
This looks like a classic case of JMeter thread groups ignoring Genesys Cloud’s strict API rate limits. The 429 errors occur when the burst of disposition calls exceeds the allowed throughput for the ap-southeast-1 region. Adjusting the ramp-up period and concurrent users in JMeter helps smooth out the burst, mimicking natural agent flow rather than a sudden spike.
Genesys Cloud’s predictive outbound system handles concurrency differently than Zendesk’s bulk imports, so treating them the same way leads to throttling. By pacing the load test, you prevent overwhelming the API endpoints. Also, consider implementing exponential backoff in your script to handle retries gracefully when rate limits are hit. This approach ensures more accurate stress testing without triggering unnecessary errors.
The 429 errors are definitely coming from the API side, not the voice path. When JMeter fires off disposition updates faster than the edge can process them, the platform throttles the requests. The previous advice on ramp-up is correct, but you also need to handle the retry logic properly in your script. Genesys Cloud returns a Retry-After header in the 429 response. You should parse that value and pause the thread for that specific duration before retrying.
Here is a snippet for a JSR223 PostProcessor in JMeter to handle this automatically:
def responseCode = prev.getResponseCode()
if (responseCode == "429") {
def retryAfter = prev.getResponseHeader("Retry-After")
if (retryAfter) {
log.info("Rate limited. Retrying after ${retryAfter} seconds")
SampleResult.setIgnore()
Thread.sleep(retryAfter.toLong() * 1000)
Also, check your campaign configuration. If you are simulating predictive dialing, the system expects a certain cadence. A sudden burst of dispositions without corresponding call events might trigger fraud detection or rate limits on the tenant level, not just the API gateway. Make sure your JMeter test includes the initial call setup requests, not just the disposition updates.
In ap-southeast-1, the latency to the edge is higher, so the window for valid request sequencing is tighter. If you are only sending dispositions, the server might be waiting for the call record to finalize. Ensure your test data matches the state machine expectations. RFC 3261 principles apply loosely here regarding transaction timing. If the server sees a disposition for a call ID that hasn’t been fully registered or closed in the local cache, it might reject the batch.
Keep the thread count low. 50 is fine, but ensure the loop count doesn’t create a hidden multiplier effect. Watch the x-request-id header in the responses. If you see duplicates, your script is re-sending failed requests without checking the status correctly.
The previous answers about JMeter ramp-up are fine for basic load testing, but they miss the point if you’re actually trying to validate API resilience for an automation pipeline. I don’t run load tests with JMeter for GC APIs. I write Python scripts that respect the Retry-After header and implement exponential backoff with jitter. If you’re hitting 429s in ap-southeast-1, you’re likely hammering the edge without any client-side circuit breaking.
Here’s how I handle it in our CI/CD automation. I use requests.Session to persist cookies and headers, and I parse the Retry-After header directly. If it’s missing, I fall back to a standard backoff. This prevents the deadlock situations I mentioned in the WFM thread.
Warning: Don’t ignore the Retry-After header. It’s not just a suggestion. Ignoring it will get your client IP temporarily banned by the WAF. Also, make sure you’re using the correct region endpoint. ap-southeast-1 has different throughput limits than us-east-1.
