Predictive Outbound 429 errors at 500 concurrent calls in ap-southeast-1
Struggling to figure out why the /api/v2/outbound/campaigns endpoint returns 429 Too Many Requests when JMeter hits 500 concurrent threads. The JMeter script is configured for a 5-second ramp-up, yet the Genesys Cloud API rate limit seems to trigger immediately.
Environment details: Genesys Cloud platform, ap-southeast-1 region. JMeter version 5.6.2. The error response includes a Retry-After header of 60 seconds. Increasing the ramp-up time to 30 seconds does not resolve the issue.
Is there a specific rate limit for Predictive Outbound campaign status updates during load tests? The documentation mentions general API limits but does not specify thresholds for high-concurrency outbound dialing scenarios. Any configuration tweaks for the JMeter HTTP Request sampler to avoid hitting these limits?
This is typically caused by the fundamental difference in how Genesys Cloud handles predictive dialer scaling compared to Zendesk’s simple task queuing. In Zendesk, you might just dump tickets into a queue and let agents pick them up, but Genesys Cloud’s outbound engine relies on strict rate limiting for campaign API calls to prevent system overload. The 429 error at 500 concurrent threads usually means you are hitting the endpoint limit for campaign configuration updates, not the actual call volume limit.
You need to separate the campaign setup from the execution. Do not use JMeter to simulate call attempts via the /outbound/campaigns endpoint. Instead, configure the campaign’s “Calls per Minute” (CPM) and “Concurrent Calls” settings directly in the Admin UI or via a single, controlled API call. The predictive dialer manages the concurrency internally once the campaign is active.
If you are trying to simulate load for testing, target the POST /api/v2/outbound/campaigns/{campaignId}/start endpoint once, then let the platform handle the dialing. Do not hammer the campaign configuration endpoints. For actual dialing capacity, check your org’s licensed concurrent call limit in the org settings.
Here is a sample configuration for setting CPM safely:
 "callsPerMinute": 100,
 "concurrentCalls": 50,
 "status": "ACTIVE"
Ensure your JMeter script is not repeatedly calling the campaign update endpoints. The rate limit is per endpoint, not per org.
  • Campaign CPM limits
  • Org concurrent call license
  • API rate limiting headers
  • Predictive dialer flow logic
  • Zendesk vs GC queueing
This happens because the campaign configuration endpoint having a distinct rate limit separate from the predictive engine’s call flow logic. The suggestion above correctly identifies the limit type, but the fix requires adjusting the request pattern, not just the ramp-up time.
  • Change the JMeter strategy from concurrent updates to a serialized update pattern. The API allows ~60 requests per minute for campaign config.
  • Use the Retry-After header dynamically in the script. Do not hardcode sleep times.
  • Implement exponential backoff in the JMeter BeanShell post-processor.
Example logic:
int retryAfter = Integer.parseInt(prev.getResponseHeader("Retry-After"));
Thread.sleep(retryAfter * 1000 + (Math.random() * 1000));
The 429 response is a hard block. Sending 500 threads to /api/v2/outbound/campaigns will fail regardless of region. The solution is to decouple the configuration push from the load test. Push config once, then test the call flow endpoints which have higher throughput limits. This aligns with standard CX as Code deployment patterns where state changes are idempotent and sequential.
