Predictive Dialer SIP 486 Busy on BYOC Trunk Despite Idle Status
I’ve spent hours trying to figure out why our Singapore predictive dialer is receiving SIP 486 Busy Here responses from our secondary BYOC trunk. The trunk registration is stable, and no calls are actively bridged.
Environment:
  • Genesys Cloud 2024-10
  • BYOC Trunk: Singapore Secondary Carrier
  • Dialer Mode: Predictive
The outbound routing logic correctly selects this trunk when the primary is saturated. Any insights on carrier-specific busy handling?
This is caused by carrier-side congestion logic overriding idle trunk status. Check if the SIP trunk is marked as “busy” in Genesys Cloud due to failed registrations or high error rates.
Parameter Value
Trunk State Verify in Admin > Telephony
Error Rate Check recent call logs
Adjust the trunk’s maximum concurrent calls if the carrier is throttling.
The main issue here is that Genesys Cloud’s predictive dialer treats trunk availability differently than Zendesk’s static ticket queues. While Zendesk simply assigns tasks to agents based on availability, Genesys Cloud evaluates real-time SIP signaling states. A 486 Busy Here response often indicates the carrier is rejecting new sessions despite the trunk appearing idle in the Genesys admin console. This discrepancy usually stems from how the outbound flow handles trunk selection logic versus the actual SIP registration health.
Check the trunk’s error rate thresholds in Admin > Telephony. If the carrier is returning 486s frequently, Genesys might temporarily flag the trunk as degraded. Unlike Zendesk’s flexible macro definitions, Genesys Cloud requires explicit trunk routing rules. Ensure your outbound flow has a fallback trunk configured to bypass the secondary carrier if it starts returning busy signals. This prevents the dialer from getting stuck attempting to use a trunk that the carrier has effectively throttled.
Pretty sure the predictive dialer’s trunk selection logic in Genesys Cloud is strictly governed by the SIP Trunk Status and Concurrent Call Limit settings within the Outbound Campaign configuration. While the trunk may appear idle in the Telephony dashboard, the predictive algorithm often rejects sessions if the Trunk Error Rate exceeds the threshold defined in Admin > Telephony > SIP Trunks. This behavior is distinct from standard queue routing, which relies on agent availability rather than SIP signaling states.
To resolve this, verify that the Busy Handling Strategy in the outbound flow is set to Retry on 486 rather than Fail Fast. Additionally, ensure the Max Concurrent Calls for the Singapore secondary carrier aligns with the provider’s contract limits. Misalignment here causes the platform to preemptively mark the trunk as unavailable, resulting in SIP 486 responses even when no active bridges exist. Checking the Trunk Health metrics in the Performance dashboard will confirm if the rejection is platform-side or carrier-side.
The docs actually state that BYOC trunks operate under strict carrier-imposed concurrency limits that often differ from the platform’s internal status indicators. When a predictive dialer initiates a rapid burst of calls, the carrier may reject sessions with a 486 Busy Here if their internal session timers have not fully cleared from previous attempts, even if Genesys Cloud reports the trunk as idle. This is a common synchronization gap between SIP signaling and platform state.
For AppFoundry integrations monitoring these events, it is crucial to implement exponential backoff logic in the retry mechanism to prevent triggering carrier-side rate limiting. The platform API provides webhook events for trunk state changes, but these may lag behind real-time SIP failures. Refer to the support article on “Handling SIP 486 Responses in Predictive Dialing Environments” for detailed configuration guidelines on adjusting the dial rate and retry intervals to align with carrier capabilities. Adjusting the concurrent call limit in the outbound campaign settings often mitigates this issue by pacing the call initiation rate.
