The conversational architecture relies on a natural cadence before agent handoff. We’ve structured the predictive dialer flow with a custom Architect canvas that delivers a TTS greeting, captures DTMF confirmation, and bridges the session. Containment metrics typically stabilize near sixty-two percent during pilot phases, though the predictive ratio appears to be choking on the callback routing. Apologies for the beginner inquiry, as pacing thresholds continue to get conflated with the actual campaign throttle parameters.
The dialer throws a 4033 CampaignPaused_InvalidPredictiveConfig error when the campaign hits roughly twelve concurrent rings. Console shows the outbound queue dropping to zero active sessions. We’re running CXone Architect version 14.2.1 on the US-EAST-1 region. Flow ID is OB-RETAIL-04A. Every time the predictive engine scales up, the call control module returns a timeout on the POST /api/v2/outbound/campaigns/{id}/progress endpoint. The payload looks clean, but it’s flagging a mismatch on the maxConcurrentCalls field.
Adjusted the user experience layer to delay the TTS playback by two hundred milliseconds, thinking the speech recognition buffer was colliding with the dial tone. Logs still show the exact same failure pattern, so it’s not a buffer collision. Containment metrics are doing jack all after the third ring, which breaks the whole conversational design mapped out for the client. The architect canvas shows the Set Conversation State block firing, but the outbound routing engine never picks up the bridge request.
Documentation mentions adjusting the answer machine detection sensitivity, but that feels like a voice IVR setting rather than an outbound pacing variable. The whole user journey falls apart because the dialer keeps slamming the brakes. Might the maxConcurrentCalls limit actually tie into the WEM session pool instead of the voice trunk capacity? The flow just hangs at the Wait For Answer block until the timeout triggers.
Are you pointing the callback routing to a static queue or a dynamic user endpoint? The 4033 usually means the outbound engine can’t resolve the destination for the predictive handoff. When the canvas bridges the session, the routing URL needs to match exactly what the Outbound API expects. If you’re pushing config updates through a script, watch out for the default rate limits. The platform caps you at roughly one hundred calls per minute for campaign PATCH requests. You’ll get throttled fast if the loop runs too tight.
Here’s a quick Node snippet to verify and fix the callback routing payload:
Double check that queue ID. Mismatched routing entities break the containment calculation instantly. The outbound API doesn’t validate the routing entity until the first call attempt fires. That’s why the metrics look fine in the UI but fail in production. Predictive ratios need a buffer of around fifteen percent to stop dropping rings. Run the script with a ten second delay between batches if you hit a 429. The pacing thresholds will stabilize once the routing path clears. Worth checking the queue status first.
The dialer throws a 4033 CampaignPaused_InvalidPredictiveConfig error when the campaign hits roughly twelve concurrent rings. Console shows the outbound queue dropping to zero active sessions. We’re running CXone Architect version 14.2.1 on the US-EAST-1 region. Flow ID is OB-RETAIL-04A. Every time the predictive engine scales up, the call control module returns a timeout on the campaign progress endpoint. The payload looks clean, but it’s flagging a mismatch on the maxConcurrentCalls field.
Are you routing the callback to a static queue or a skill group? You’ll hit that 4033 error when the outbound engine misses the destination ID, so check the routing configuration in Campaign Management. Verify the user has the appropriate outbound campaign permissions. Investigate the campaign’s ‘Destination’ setting and confirm the queue or skill group UUID is correctly populated.
