The outbound dialer integration is throwing a 422 Unprocessable Entity when the Architect flow attempts to sync a GDPR Article 7 withdrawal event back to the contact list. We’re running on the Frankfurt data center to satisfy data residency requirements, and the flow version sits at 2.8. The service account has full outbound and recording scopes, but the attempt to update the contact record keeps rejecting the status: EXCLUDED field alongside the consent token metadata.
Payload structure matches the schema documented in the API reference. A community post from late last year suggested wrapping the consent withdrawal timestamp in ISO 8601 format, which we’ve already implemented. The test campaign mic stays hot, but the webhook callback never updates the record. Queue metrics show a 15 percent drop in contact attempts because the dialer treats the stale consent records as valid under Article 6(1)(a). Timestamps are off by three hours again.
The validation_errors array points to a mismatch on the consent_withdrawal_id field, even though the value matches the UUID generated by the initial opt-in event. The retention policy is doing jack all while the flow retries every 30 seconds.
"status": 422,
"status_message": "Unprocessable Entity",
"code": "bad.request",
"message": "Validation failed for the following fields: consent_withdrawal_id",
"details": [
"message": "The consent_withdrawal_id must reference an active audit trail entry in the Frankfurt region.",
"parameter": "consent_withdrawal_id"
Python SDK version is 12.0.21. The outbound campaign uses predictive dialing with a max concurrent call limit of 50. Data minimization protocols require immediate exclusion upon withdrawal, so the 422 response blocks compliance workflows. The API gateway logs show the request originates from the correct Frankfurt edge node. The flow won’t transition to the error handling block.
curl -X POST "https://api.campus.equinix.genesiscloud.com/api/v2/outbound/contactlists/8f3a9c2e-1b4d-4a5f-9e2c-7d8b6a1c0f3e/contacts" -H "Authorization: Bearer <token>" -H "Content-Type: application/json" -d '{"contact_id": "9a2b3c4d-5e6f-7g8h-9i0j-1k2l3m4n5o6p", "status": "EXCLUDED", "consent_withdrawal_id": "c8d7e6f5-4a3b-2c1d-0e9f-8g7h6i5j4k3l"}'
