Outbound calls distribution
I am fairly new to using Genesys for outbound calling. Where can I find the arguments how Genesys distributed all the “answers calls” to the agents?
I want the agent that has been waiting the longest to get the next call, but dosent seems like it work that way today.
Or if anyone can send me a link where I can read about it :slight_smile:
Regards,
You do that on URS distribution strategy rule, not Outbound itself…check URS strategies with Stats distribution (upper part of target object on IRD)
Check docs for call flows and components interactions.
Your post does not make a sense at all. What type of campaign are you using? If the campaign calls are distributed trough the routing strategy, you should configure the used statistics within target block as is standard.
I strongly recommend to you visit any Genesys training or learn more about Genesys.
Do you have any suggestions where I can learn more?
I have been reading a lot on docs.genesys.com, but it is very complex :slight_smile:
Genesys is not simple ;D Welcome to it
As said, check URS docs, there are strategies samples. I pointed already which property and object to look at
