NR Reason code display at WWE
Hi all,
can you please advise whether it is available to make NR Reason code available only for selected agents at WWE?
The issue is: we need to make different NR codes for different Agent Groups.
best to use as list item and have it in your routing, split it out that way
Hi Tambo,
thanks for the option!
Indeed we’ve resolved the issue by setting list of specific NR codes to Agent Groups Application options.
