Not Ready Reason
Whether it is possible in the CCPulse to show the Not Ready reason duration in a single custom stat. i.e Break,Lunch.
I have created the custom stat for current not ready time.
MainMask- Not Ready For Next Call
Subject - AgentStatus
Category-CurrentTime
Objects - Agent,GroupAgents,Place,GroupPlaces.
I have created the separate stat to apply filters for each not ready reason.
Looking Forward for Your Suggestions.
Search the forum please. With VB script is possible
Thanks For your Reply,
I have tried the following method, In the Filter options if we give the Conditions such as Break ||[or] Lunch.
When the agent goes to the Not ready Reason Break It will start the duration but when the agent goes to the not ready reason lunch , the stat not get counting from start. Kindly looking forward for your suggestions.
I used the VB Script to display the not ready reason name, But i need the suggestions on the not ready reason duration in the single stat .
search for ccpulse on here there are plenty of posts to tell you exactly what to do with filters etc
or search PairExist which will give you the filters
You’ll find more info in StatServer user guide, search for filters.
Here’s an example : PairExists(Reasons, “NotReadyReasonCode”, [value])
